Foton 254 clutch failure?? Gulp!
/ Foton 254 clutch failure?? Gulp! #1
succor
Saskatoon, SK, Canada
foton 254
Hello everyone, it's been awhile since I've been on this forum but could be a very sad day for me anyway! 275 hours on my 2006 254 foton. The 3 years I've owned it it has ran fine and consistently for me till recently. I've read through what posts I could find on this forum to possibly no prevail and finding a reputable china tractor mechanic without being to pricey! The other day I started my tractor and went to put it in gear, GRIND! I could pop it into 1st low and it would go with or without the clutch pedal. After awhile of driving I eventually could wiggle the clutch to let go on the drive and shift. Same thing with the PTO, I would push the pedal right to the very end before it would just disengage. OK, it looks like clutch adjust. The funny thing is it never did this before. 2 stage clutch with 6 fingers, I've got the books with the specs with lot's of reading and away I went. Took the loader off and 1st inspection shows a little rust in areas but not severe with some moisture in there. I notice that when the pedal is pushed, I can see the plate move and separate evenly but only about 1mm or maybe 1.5mm; not a lot of movement. Should this open more or is this normal? Next I've adjusted TOB gaps and PTO finger gaps to the book spec with no prevail on clutch movement. I've read about roll pins but in this particular design, it looks like the shaft on the clutch pedal arm that goes into the bell housing goes right through to the other side cause I can see it pivot on the other side when I push the clutch. My guess is this shaft goes through a bushing with two lock pins for the fork to the other side. Inside it looks fine and it looks like it's moving fine but unsure. One post shows a fella with a foton 404 where he marked the clutch arm with very little rotation. Mine moves about the same but it's welded at this point where his just comes off with the roll pin falling out. The fingers and TOB seem to look fine and no grinding or abnormal movement that I can see or feel but yest when I start the tractor, grind! I don't know if this clutch pivot arm comes out but I hazzard a guess no. It has to be my adjustment technique or something has not been done right from the get go and has been failing for 3 years without notice? I've spent 12 hours on this adjusting to spec with no prevail. I sure wish I was missing something at this point as it could save me a few thousand dollars so I'm calling out to the china tractor experts out there for some much needed HELP!!
sigh
Cory
/ Foton 254 clutch failure?? Gulp! #2
Well that is an unusual failure mode. They usually fail by slipping/failing to fully engage. Moisture inside is not a good sign. Was there any standing water in the bottom. There is a drain hole down at the bottom to allow any moisture that collects to drain away. Sometimes that hole gets clogged, which allows any moisture that collects inside to stay inside which repeatedly coats and recosts all the internal parts with moisture during condensation/evaporation... Where do you keep your tractor, Inside or Outside, covered or uncovered?
This type clutch has pretty tight tollerances, and requires verty little movement to function. Unfortunatly this also means that any debris in the clutch will hinder it's ability to disengage. It only releases the clutch disc enough to slip, it dosn't really let it go or separate. IF the plates have become corroded, and since they have been pollished to bare clean metal by the discs they will corrode the worst, the additional friction this causes is most likley your problem.
I would say make sure the drain hole is clear of debris and that any moisture can drain away. If the side covers are still off, do your best to get things dried off and as much moisture out of the case as possible. heating the case or hot air from a small space heater pumped into the case thru the access holes will evaporate and carry the air out of the case. You say it loosens up and functions with use and when things warm up a little? I would say do this every day, getting the machine up to full operating temp. IF it can stay dry, regular usage should help the discs re-pollish the plates smooth again and shed rust debris.
Good Luck.
Thanks Ron. 2 winters ago was the worst where the weep hole was plugged with a bit of frozen water in it so it wouldn't crank over. I have plans this year to build a small garage to fit this tractor in to get out of the elements so my fault on this one. Better sooner than later. Yeh, it was pretty damp in there with some rusty spots around the clutch. Everything is moving OK and evenly so no problems there. It sat more last winter due to warm weather and no snow go figure; perfect for a clutch eh! Maybe when I drive it again, got some rototilling to do I can work the clutch a little at a time and like you said, hopefully it can fix itself a bit. The PTO is probably the same thing with rust just not as bad because I can actually disengage it.
Time will tell.
Cory
/ Foton 254 clutch failure?? Gulp! #4
A little rust is normal. As long as the weep hole is open, the heat generated by friction is usually sufficient to overcome moisture. But 6 fingered clutches adjust a whole lot different, they don't lend themselves to adjusting through the inspection window in the same manner as their 3 fingered cousins. So I hope you didn't lead yourself astray by trying to adjust it as a 3 finger.
A "welded" clutch release lever however, makes me pause. Please clarify, because this is not what I'd consider normal for a Foton
//greg//
Hey Greg, what I mean about the weld is the clutch arm that pivots off the pedal by the bell housing. This arm is welded to a shaft which goes right through the bell housing with the fork attached to it. So I believe there is no external roll pin on this clutch pedal arm. I've been very careful for the adjustment and followed the specs exactly. 6 finger is easy to adjust in my mind as long as your careful. External linkage for 2.5 mm gap to TOB first 3 fingers even for main clutch and last 3 fingers for PTO clutch. Nothing looks funny unless like I said something was messed up on install or rust or internal roll pins which I cannot see because rotation looks tight on the fork to TOB. I got it out of the rain and am drying the bell housing. I guess that's all I can do for now.
Cory
/ Foton 254 clutch failure?? Gulp! #6
Yeah, the 1st three fingers are about the same as with the more common 3 finger clutchpack. But the second set is more difficult to calibrate. It's important that each of the 3 fingers in a set makes contact with the throwout bearing simultaneously. The tolerance between fingers is something like 0.1 millimeter. And I don't have the exact numbers anymore, the clutch data went with mine when I sold it. But I seem to recall the PTO fingers were at least another 6mm or so behind the main drive fingers.
Any chance there's a 2-stage clutch diagram in your owner's manual? Not the exploded diagram in the parts manual, I'm hoping there might be gap specs in your owner's manual clutch diagram. That's where they were for the 9 inch six finger in my 35 horse.
//greg//
Hey Greg, yeh I have the good ole 2 dimensional diagram of both single and dual stage clutches. The 3 main are 2.5mm +/ - 0.5 and the PTO fingers are 10.5 +/ - 0.5 all from the TOB. It does give the stack heights but no way of actually measuring which is the iffy part. I try to go as exact as I can. When we get some sun, I'll try to get it lose again and so called ride the clutch ever so slightly to see if I can free it. Unless there is something obvious I'm missing, that's all I can do.
Cory
/ Foton 254 clutch failure?? Gulp! #8
Ok, 8mm difference between clusters (finger sets). Nothing you can do about exacting the stack height unless/until the tractor is split. That's most accurately done on the bench. But understand that the +/-0.5 tolerances you cited above are tied to the bearing gap specs. That is, how far away each finger cluster is from the vertical face of the throwout bearing.
The +/-0.1mm spec to which I referred above is among each of the 3 fingers that comprise one cluster (PTO or main). That's what ensures simultaneous contact of 3 fingers against the bearing face. Non-simultaneous contact results in the TOB pushing the fingers at an angle, which can fail to completely release of the friction disc. On a tractor that's not split, that 0.1mm is what's difficult to achieve on the PTO set. The sequence is to achieve that 0.1mm tolerance before setting the 2.5mm finger gap with the bearing. Assuming a tolerable stack height in the first place - and that this sequence was followed - the 10.5mm gap for the PTO cluster will already be established by default.
//greg//
Hey Greg I understand, fingers have to touch the TOB at exactly the same time or we got a frizbee going sideways sort of speak. Not a good thing when your only separating clutch faces by a hair. However I think I'm pretty close because when I rotate the clutch the spacing around looks pretty even when it's separated. I try to adjust these fingers ever so slightly to achieve as best as possible.
Cory
/ Foton 254 clutch failure?? Gulp! #10
Ok, lets get back to your original problem then - grinding. We should start with the obvious first - pedal travel. Check the stop bolt to see if the jam nut may have come loose. It's uncommon, but a stop bolt that's backed out unnoticed will stop the pedal short of full travel.
Then check under the left floorboard for bent or jammed linkage. If that's artificially shortened, it will also inhibit full pedal travel. One guy tore up a plastic pedal bushing, which also served to shorten the pedal travel.
//greg//
stop bolt was good and pedal travel sees good. I have been playing with these adjustments the past 2 days looking for something obvious but nothing so far other than the rust moisture issue which was quite evident in the bell housing? With a 2 stage clutch you have so much travel with the first 3 fingers than the pto travel after. The only thing though with the stop bolt, I can't press the pedal far enough down to even reach the stop bolt without my foot going awkward. The book calls for 35mm where I'm at about 50mm so maybe too much foot travel? I know you could easily misadjust because you got finger adjustments, stop bolt and linkage to deal with. I was trying to use logic here when I think grinding gears, to me, the clutch is not disengaging the motor from the backend so the clutch pack opening is the issue. With my adjustments, it doesn't matter what I play with, if I achieve the specs in the book, the pedal movement and clutch opening all is the same which is a very small opening in the clutch itself which seems to be the norm for a 2 stage clutch. Forgive if I'm sidestepping in my comments, just thinkin as I'm typin. One thing I though of which is probably wrong but only a thought was to increase the distance between the clutch fingers to give more travel with the main clutch while still maintaining the right distance with the pto clutch as well. That would be achieved by the stop bolt correct? Also remember here that I'm no clutch expert but I'm learning while I have it in the garage drying out.
Cory
Well, I thought I would uploads the specs from my manual to this site for now as well as future use in case nobody has a manual. For the dual acting picture, I'm wondering if I can actual measure the 78.5mm stage because it looks like the bolt portion which controls the pto drive which I can see through the bell housing. If it's possible, theoretically, I could adjust close to the desired range specified, than adjust back to the first 3 fingers, than to the TOB via clutch linkage. Just a thought.
Cory
/ Foton 254 clutch failure?? Gulp! #13
Only other thing I can think of at the moment is the clutch fork. It's the device on the other side of the release arm that you said is welded to the release shaft. You can consult your parts manual, but the fork is typically attached to the shaft with nested roll pins. If/when they break, the result is a failure to push the throwout bearing far enough forward. Incomplete bearing travel results in incomplete clutch release, incomplete clutch release results in grinding gears.
Unfortunately - short of one of those specialty troubleshooting cameras - the only way to find out for sure means splitting the tractor.
//greg//
Looking at the parts book which confirms I was right is that there is no roll pins in the clutch rocker arm as they call it. This rocker arm goes through the cast housing through the collar of the fork which has 2 giant through pins to lock the rocker arm to the fork for rotation. There is no slip in this action which is a good fix in part of foton I guess. They were obviously aware of roll pin failures to change this design. Today is sunny so I'll finalize my adjustment procedure and see what I can do about releasing it on the move.
Cory
/ Foton 254 clutch failure?? Gulp! #15
hey greg.. when did you get the greene tractor? last I remember you have the chinese one...
So far so good!! Clutch works perfectly! Even better after my adjustments. However, here is what I noticed driving not standing still necessarily, some water droplets began flying out the clutch inspection opening as I left my loader mount off. I parked the tractor and noticed a very small amount of water down further by the flywheel closer to the starter side. I looked around the TOB which seemed dry, no water droplets except that small puddle at the bottom of the housing. Next I checked my gear oil and noticed an almost bright emulsion mixed in with the gear oil so there is water in the transfer case and such. Time for an oil change the only place I can see water getting in is around the gear shift cause the boot is damaged and possibly where the starter motor is mounted as well. Maybe water is splashing through where the TOB is from the transfer case but again it looked dry. Long story short is if it can sit in a shed, way better.
Cory
/ Foton 254 clutch failure?? Gulp! #17
Four Chinese actually. Traded the last pair for this JD3720 a little over a year ago. Retired now, time to spoil myself.
//greg//
/ Foton 254 clutch failure?? Gulp! #18
I got the impression your loader arm supports bolt over the inspection ports. they don't on the bigger Fotons, but I'm not sure about your little one. If true, you probably need water-resistant gaskets to seal the gap. Also, storing a tractor outdoors precipitates condensation on the inside walls of the cast steel housings. When the tractor is started, vibration mixes the condensation with the gear oil. Then the constant agitation of the oil while the tractor is worked eventually creates an emulsion.
It's important to realize that the emulsion is now clinging to the sides of the housings above the oil line. Flush that out before refilling with fresh gear oil, or you'll just contaminate what you just poured in.
//greg//
What and how do you flush the tranny out? Is there some sort of oil you put in first than run it. Never had to do this before. Yeh the loader mount goes right over the inspection hole so I will put a gasket there. Of course, the inspection hole is on the opposite side of the clutch pedal.
Cory
/ Foton 254 clutch failure?? Gulp! #20
//greg//
well.. the greene ones are spoilers I guess.. ;)
