Kioti Paint
/ Kioti Paint #21
My machine was made 6-11, I am not new to this...Check the color on my photo's in this thread. That is not a black I ever seen.
Your subframe shots in the skidplate thread show a black chassis as I expected. The other earlier color is a much lighter grey. No one said you were new to anything....just passing along info to those who might not know about how tractors are sold in relation to manufacture date; possibly also including you....
/ Kioti Paint #22
If you think thats black you best see a eye doc.
/ Kioti Paint #23
I see grey in Murphy's photos. You might be looking at my tractor frame which is indeed jet black. Also, my frame is straight while his is stepped or zigzag.
/ Kioti Paint #24
Those with a Hydro.. on your hydro filter, not the hydraulic filter but the hydro filter does yours have a metal guard (skidplate) under it? Mine does.
James K0UA
/ Kioti Paint #25
James K0UA
Photo please Sir James.
/ Kioti Paint #26
I will now have to post pics to lay this thing to rest, hopefully once and for all.:thumbsup:
Pics to follow soon....
/ Kioti Paint #27
You taking pics of my tractor???:laughing:Get out of my barn...
/ Kioti Paint #28
James K0UA
Like this:
/ Kioti Paint #29
Like this:
By Memory: Yes. that is what I believe mine looks like also.
Now back to the color thing, Island, I would call your color on those lower parts dark gray, NOT black.. do you agree?
James K0UA
/ Kioti Paint #30
YOUR tractor?! :confused2::confused:
Wow Murph, maybe you should see a shrink; not everything is about Your tractor...
And I can't find your west of the Atlantic barn either...
/ Kioti Paint #31
James K0UA
There are grey painted parts attached to the transmission (grey) but if you look at the bottom of the photo, there is a clearly black chassis frame piece 1/2x3" solid steel. That black part is what is grey on the newer tractors. It is also a stepped or zigzag series of bends on the newer machines while mine is a straight piece of steel front FEL mount to rear axle. See photo below for side view on the right side of the black piece and the mount on the FEL post. Those black pieces are different on the newer tractors. They are grey and not straight.
/ Kioti Paint #32
I see your point now, I will try to take a picture at some point in the daylight, and I am pretty sure mine are dark gray.
/ Kioti Paint #33
Hey guys.
I have a 2010 and it is the "new" charcol grey. I saw a left over 2009 DK45SE HST @ brownies in Nelsonville last fall. It was the "light grey" model but had a new "charcol grey" KL401 attached to it.
When I looked at it, the dark grey looked "black" in contrast to the light grey.
What IT is describing is odd to say the least. Wonder what happened there???
Oh, I bought a can of the charcol grey from the dealer. As it should, it is a perfect match.
/ Kioti Paint #34
I didn't say what color your tractor is nor do I care. Your the one telling me the color of mine and giving me backround on dates of manufactur.;)
As you posted "Your subframe shots in the skidplate thread show a black chassis as I expected"
/ Kioti Paint #35
I repeat: I think Coyote looked at the photos of my older DK40se which does indeed have a black chassis frame.
I can also testify that my eyes agree with Murphy's and that his chassis frame is grey.
I'm starting to feel like a diplomat or mediator! Or maybe like a Mother: you boys cut it out!:laughing:
/ Kioti Paint #36
My original post in this thread was asking if anyone knew what the new black that replaced the former grey was as an aftermarket paint color. Some call or see the new color as grey, albeit dark grey, and others like me see it by comparison to the light grey as black in color. It is not midnight black, but it sure as heck isn't grey like a battleship either.
Murph, Your tractor is just that - yours. Keep it west of the Atlantic; hopefully as close to the Pacific as possible...:laughing:
IT, youse a mudder alright:D
/ Kioti Paint #37
I give...:confused:The color is listed 7784-830 rustolem Dark Grey.
/ Kioti Paint #38
Now I'm confused? Are you saying the new dark grey, almost black Kioti paint color on the lower part of the DK's is Rustoleum 7784-830? If so, where did you get this info? I did not see it in this thread, or possibly I missed the reference?
/ Kioti Paint #39
I posted it in post 5, but I did not say that it was for sure that color, I just said another member MtViewRanch said he used it for Kioti to match his hydraulic cylinders he sells.. How close it matches I don't have a clue.. I check the tractor again when I got home to-nite, and it is definitely NOT black on all of the lower parts.. and they are all the same charcoal gray color, not some of them black and some gray like Island's
James K0UA
/ Kioti Paint #40
All we need to do is take something with the different colors to an auto paint facility that has the computer for color matching and get the mix needed and post it and what the color names are...
Just my :2cents: worth..
Tom
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2015 Ford F-550 4x4 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2015 Ford F-550...
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
1000 GALLON FLAT BOTTOM POLY TANK (A64278)
1000 GALLON FLAT...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
