Anybody got a list of DKxx common tools?
   / Anybody got a list of DKxx common tools? #21
I was shocked too. I paid something slightly under $100 which is bad enough. See if you can borrow one to try. It is somewhat more than a simple convenience item but hardly critical. I'd rank it somewhere between the draft control and cup holder.:laughing:
Well, thats a pretty good comparison. Draft control I could do without but cupholder? Maybe ?
   / Anybody got a list of DKxx common tools? #22
I agree. Makes greasing the tractor both faster and less tiresome. I also have gotten used to the sound and speed so I can tell pretty quickly if a zerk is plugged. Also, because I don't need to be grunting and pushing, I can pay attention to watching for signs of excess grease oozing out around the pins so I can stop pumping faster and create less of a mess.
Agree with all. When I grease, I park my tractor next to my barn where I have an air compressor; so I bought an air-operated grease gun (about $20 on ebay). Works great so far.
   / Anybody got a list of DKxx common tools? #23
Now your talking!!!
   / Anybody got a list of DKxx common tools? #24
That makes a lot of sense. I'm sure it is just as effective as the battery powered type and except for being tethered to the air hose it really has no downside. With the savings over battery type you could grab one of those portable 5 gallon air tanks from HF and have full mobility too.
   / Anybody got a list of DKxx common tools? #25
Common item. Check Amazon or Northern Tool for starters. Again, there are at least two versions. One is 12v and works fine. Probably marketed as consumer grade. The other one is ?14.4 or higher voltage and is about double the price as I recall. I have both and don't notice a substantial difference in construction.
Here is the current 12v version, looks a bit different than mine, at least the case is different and is about $80 more than I paid. Could be I bought mine on sale somewhere else on line. Amazon.com: Lincoln Lubrication 1244 PowerLuber 12 Volt Cordless Grease Gun with Battery Kit: Home Improvement
I just checked, and we have the 12v version.
   / Anybody got a list of DKxx common tools? #26
Ok, you guys got me curious. How much better is an air or battery operated grease gun? What is the trouble using the manual gun?
   / Anybody got a list of DKxx common tools? #27
Neither is critical surely. I tend to grab my electric if I am going over the whole tractor, loader, backhoe with maybe 40 zerks to service. It is convenient but the thing I really like is the ability to position my eye so I can see grease extruding from the greased joint and not be focused on pumping. I also use a manual lever style which I am more likely to grab for doing a few zerks rather than getting the electric out of the case etc. The electric has a flexible hose so easier to access some zerks which I cannot get with my rigid tube manual grease gun.
For someone in charge of greasing hundreds of zerks per day I'd say the electric is great. For the rest of us it is a nice but not critical piece of kit.
   / Anybody got a list of DKxx common tools? #28
The main issue with the manual "scissors-style" gun is that it takes both hands to pump do you don't have a spare hand to keep the nozzle on the zerk.
   / Anybody got a list of DKxx common tools? #29
That is why my manual gun has a rigid steel extension rather than flexible.
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
