Ballast Sliding on hills with a 2wd
   / Sliding on hills with a 2wd #1
bbse
Nashville, TN
Mahindra 3325
I have been working with this Ford 1920. It is a powerful little tractor but this one is a 2wd w/Ag's. I filled the rears with water to the top of the rims(right below the valve stem) and that helped. It is very stable on the side hills that I mow but going down the steeper ones it starts sliding and I just have to ride her down. It has a lot of ballast on the front end and I pull a KK 5 ft brush cutter. Other than spending a ton of money for more wheel weights are there any tricks to stop the sliding?
   / Sliding on hills with a 2wd #2
If my TC29 starts sliding going down a hill it is to steep for me to be on with that machine. Just my opinion. And I admit I have been places I should not have been on all my tractors.
Bill
I agree that is true in a perfect world but I have to go down that hill to get to my fields....plus I have to mow that hill. It is attached to my back yard. This is my first two wd and the only tractor I have right now so I have to make it work.
   / Sliding on hills with a 2wd #4
I used to have a 2WD IH424 and it was a great hilside tractor till you were going down hill and the it was a hill slide tractor:D. It helped to run chains and I did all year long.
Seems like I read one time about reversing the tread direction....axnyone ever tried that?
   / Sliding on hills with a 2wd #6
You are probably aware of this already. (1) Before descending a slope, shift to a gear low enough to control speed without using brakes (2) Avoid changing gears when climbing or descending a slope (3) If operating on a slope, never disengage the clutch or shift levers to neutral. Doing so could cause loss of control. Best Wishes and remain safe.
   / Sliding on hills with a 2wd #7
Backing up or down the hill will reverse the thread direction if you want to test what you may have read.
Not necesarily. I can drive up the steepest part of the hills now. As to going down the lower the gear the sooner it breaks loose ...I may try a real high gear with a low rpm on the engine....
   / Sliding on hills with a 2wd #9
Think of the downhills as just fast straight-a-ways....thats what King Richard
aka Dick Burleson,8 time offroad MC dirtbike enduro champion taught the classes. Start off slow at the top,point in a safe direction, and if all else fails...gas it:D
Your funny....you really don't have to gas it, it is moving pretty fast on its own.:thumbsup:
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
3650 (A47477)
3650 (A47477)
Hydraulic spike driver (A56435)
Hydraulic spike...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2012 International DuraStar 4300 Flatbed Truck (A55973)
2012 International...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
