Grease Fitting
/ Grease Fitting #1
Mark Page
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
I need to grease the u-joints on my mowers drive line. To get to the zerks you have to slide the cone shaped safety shield down the drive shaft, which I can not do. I've removed the clips that hold them in place and they won't budge. I'm inclined to cut them off except they do keep dirt and clippings out of the joints.
/ Grease Fitting #2
Don't your cones have a little 1/2 inch access hole that you can rotate around to line up with the Zerk?
James K0UA
/ Grease Fitting #3
for the tractor side, sometimes you can access the zerk through the PTO splined receiver hole when it is off the tractor.
I also just split the shaft to grease the shaft itself.
/ Grease Fitting #5
I had to split the outer plastic on mine in order to move the shaft back and forth to hook it up, but I can get the grease gun on without moving the hub back and forth. Even with the shaft split, the hub still doesnt move back, just rotates so I cant help with how to move it back. I think it must slip on from the open end and snap in to place somehow as it is firmly in place.
If you cant get the grease gun on, I would cut a notch or a hole in it as suggested so I could line it up. THe grease zerk should be one with a 90 or 45 turn on it so it faces out. On one of my BH, there is only one point in 360 degree of rotation that the shaft has to be turned to to access the zerk, anywhere else and the knuckle joint is too tight when it is hooked to the tractor but no problem with the safety cover.
RoGator and Terragator Manuals (A63117)
RoGator and...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
