Buying Advice John Deere Imatch
/ John Deere Imatch #1
RockyCreek
2006 Kubota L4400
Question I just purchased a Imatch with my 4720 JD. Two questions will the Imatch fit Woods brush bull 6' cutter and are they any other suppliers for adapter bushings than JD they are a little high on the price for there bushings.
/ John Deere Imatch #2
Since it is a wood rotary cutter I cant see why it wouldn't fit the imatch. Deere is offering a new imatch with the adjustable top hook but last I heard it was back ordered by 2 months.As far as bushings you can get some that slip over the pin that are held in place by the standard lynch pin from TSC, their price is way less than Deere. Hope this helps, you will absolutely love the imatch. :thumbsup:
/ John Deere Imatch #4
Easiest way to find out if the cutter fits is to try it out. If it's like my Land Pride, you'll have to come up with some kind of adapter for the top link of the cutter.
I got my bushings the same place Rockgod did. Deere charges about $85 for the kit. The only thing the Deere kit has in addition is a bushing for the top link pin
/ John Deere Imatch #5
Just like Roy said.:thumbsup:
/ John Deere Imatch #6
Is there any info online about the new adjustable imatch?
/ John Deere Imatch
What's the difference between the Adapters F/ Cat. 1-2 and the Cat. 1-3 for the Imatch will they both fit correctly?
/ John Deere Imatch #8
The thickness, the Cat. 2 is 7/8" ID X 1-1/8" and the Cat. 1-3 is 7/8" ID X 1-7/16".
Cat. 1-3. will be a tighter fit.
/ John Deere Imatch #9
i use a Woods Med Duty 6' single wheel brush mower with my JD 4720 IMatch...no problems. I had the tractor and IMatch first...when I bought the woods, the Woods dealer knew what kind of bushing I needed ( I think they're just a bit larger) and put them on for the IMatch to work. Once you get it set up, it will work fine.
/ John Deere Imatch #10
Since JD brought out the Imatch alot of other tractor companies have followed suite. So have their 3 point attachments. Unless your bush hog is 15yrs old, I'd say that it has a provision to fit the Imatch. My 5 year old King Kutter tiller from TSC had an extra pin for Imatch. It fit right up. If not, like Roy mentioned earlier.
/ John Deere Imatch
Ok thanks all for the good info. Really a lot of help.
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
Pabreak 84in Hydraulic Serrated Dozer Blade Skid Steer Attachment (A61567)
Pabreak 84in...
2016 FREIGHTLINER CASCADIA 125  T/A DAY CAB TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
