Backhoe Backhoe
/ Backhoe #1
Jesse masterson
Thebes il
07 kioti dk 45s
Just curious , I bought a rhino 95c for my dk 45 and was wondering if it's common practice to put the hoe down when parked to take weight off of tractor I heard you should just like the front loader, also should you always have the boom locked when traveling
/ Backhoe #2
i drop the implements just for safety. If you got the hoe pinned so it can't drop i think thats fine. extended periods of time i would put it on the ground.
/ Backhoe #3
If I'm just moving around the digging site, I don't lock the boom or swing. If travelling further, then I lock them. You'd be surprised at how much it will bounce if you get going somewhere. If I'm done for the day, I either put the bucket on the ground or lock both. If you didn't do either, I bet the bucket would be on the ground by the next morning. Doing either takes the pressure off the hydraulics just like setting your fel bucket down. I never have extended periods of time with the bh on. If I'm done with the job, I take it off.
/ Backhoe #4
I do pretty much the same. If I'm using it and stopping work for a while I put the bucket on the ground. When it gets parked I have both locks on, usually put the locks on when I am finished using it and before I travel.
/ Backhoe
Kinda what I thought , I usually put it on the ground but I wasn't sure if all that weight sitting onrear bearings would effect them
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
