my $480 hydraulic filter
/ my $480 hydraulic filter #1
4520RX
Member
Meeker,CO
Branson 4520R
Did my 50 hour service myself, went and bought the NAPA hudraulic filter (1202) the dealer told me. But a 1202 was not in the box it happened to be a fuel filter with the same threads. Which left me with a bill for 6 hours of diagnostics @ $80 per.
/ my $480 hydraulic filter #2
i would attempt to get napa to pay it
/ my $480 hydraulic filter #3
Examples like this are why I NEVER trust the schmucks behind the parts counter. Sure, some of them MAY know what they are talking about, but I've found that the vast majority wouldn't know a (INSERT PART HERE) from a hole in the ground.
/ my $480 hydraulic filter #4
I just replaced the hydraulic filter on my NH TC55DA and it was 212 CAD incl tax (no shipping).
/ my $480 hydraulic filter #5
My experience (63 years) has been just the opposite. If you are a regular customer at NAPA, you know who to go to when you walk in the door, and they bend over backwards to help you. At the dealer it's you that gets to bend over .............Just my experience............
/ my $480 hydraulic filter #6
A Napa 1202 is the 10 micron hydraulic filter I use on the F.a.s.s system on my big trucks caterpillar engine fuel system. could it be that 10 micron filter was to restrictive?
They put a 1202 back on it and gave me back the filter that I installed. Is it normal to have the hydraulic filter on the suction side of the hydraulic pump? All the equipment I use at work have filters on the return side so you do not starve the pump and burn it up.
/ my $480 hydraulic filter #8
Did this burn your pump up?
What damage did the wrong filter cause and why so many hours diagnosis?
Just a reminder to us all - me included. There are several things every technician and parts replacer should remember and that is to make sure the part in the box looks the same as the one you are replacing; make sure the part is not damaged or altered and, if the new part has a number the number matches the box and the product you purchased. If something looks out of place find out why.
/ my $480 hydraulic filter #9
How much money did you save over the cost of a Branson filter????
I am a generic kinda guy BUT for what I paid for my tractor I will go with the OEM filters.
Five bucks I now have three OEM filters on the shelf
My pump did not burn up but it was a pain getting the tractor on the trailer with no hydraulics or power steering
/ my $480 hydraulic filter #12
I'm sorry this has happened to you and thank you for sharing because it is a tremendous learning experience for us all.
What was the micron rating of the wrong filter that was installed?
Did the tractor stop functioning after the filter change or did it take some time before nothing worked?
O dis not look up the micron of the othr filter. It took some time to lose all function, it was slow and jerky like air was in the system. While working it the cable lingage from the joystick to the valve failed which is where I shut down
2017 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2017 BOBCAT MT85...
KUBOTA BV5160 ROUND BALER (A64278)
KUBOTA BV5160...
UNVERFERTH 2755 SEED RUNNER (A64278)
UNVERFERTH 2755...
2006 Toyota Highlander Hybrid SUV (A64557)
2006 Toyota...
2010 FORD F750 BUCKET TRUCK (A63276)
2010 FORD F750...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
