A/C water leakin inside Cab
/ A/C water leakin inside Cab #1
Nelson Farms
Mississippi
John Deere 5520 Massey Ferg 383 and 1035 compact
I just got a 2001 John Deere 5520 and was baling hay today using the a/c and noticed that water was leaking around the speaker and dome light also blowing a little out the vents. What's causing this?:confused::confused2:
/ A/C water leakin inside Cab #2
Evaporator drain is clogged.
/ A/C water leakin inside Cab #3
Agree the drain is clogged, find the small plastic tubing coming down from the roof. Mine is on the rear beside the rear glass IIRC. You can try to run a wire up to clear the clog or give it a squirt of compressed air. I prefer to use a fish tape because it is less messy.
I really haven't examined the ac evaporator coil on my 4520 yet but would emphasize that keeping the air filter clean and replacing when needed will greatly reduce problems with dirt clogs in the system. If you can clean the coil after getting it unclogged it should help with efficientcy too. Use an aerosol can of indoor coil cleaner for this purpose.
I appreciate it fellas!:thumbsup:
/ A/C water leakin inside Cab #5
Pour a half and half solution of bleach and water down the drain, and likely will clean out the mold that has accumulated/grown in the pan and the tube.
/ A/C water leakin inside Cab #6
Trade it in on an open-station machine. Build yourself a nice sun-canopy.
/ A/C water leakin inside Cab #7
Lol, obviously you don't have a cab tractor with ac! Once you have one its pretty hard to go back.
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Excavator trenching bucket- one bucket per lot (A63118)
Excavator...
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59910)
2019 UTILITY VS2DX...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
