Do you guys want to talk machining here?
   / Do you guys want to talk machining here? #21
Jake,
the coolant is 95% water and 5% water soluable oil.....very little oil so the parts are cleaned easily......the lathe has a tank to recirculate and it lasts for several years till I have to replace it
Yes, that is a welding positioner.......adjustable from horiz to vert, variable speed with on/off foot pedal.....all made with surplus stuff except for the steel frame materials and casters
   / Do you guys want to talk machining here? #22
Beautifull work Dennis..!!
Do you have a video of it working?
Jake,
no issues with machine rust or anything? that's an amazing amount of cooling, you can see there'd be no heat there.
   / Do you guys want to talk machining here? #24
Heat is the enemy of machine work when trying to push the envelope of crashing carbide cutting bits and dimensional distortion......time is money, if the same work can be done in less time then production wins....
The water-soluable oil is tweeked to a 5% to 10% ratio and no machine rusting.......theoretically the machining could be done with 100% water but the machine would suffer from rust...:mad:.........Hence the oil
   / Do you guys want to talk machining here? #25
Thanks guys. Here's a link:
[ame=http://www.youtube.com/watch?v=qFcnx-YnKIA]Elmer's 45 - YouTube[/ame]
Never thought I'd see a fish fart... guess that explains those bubbles. :laughing:
   / Do you guys want to talk machining here? #29
Looks like you are ready to start makin' chips! Having had access to a Bridgeport mill and a Southbend lathe in the past, I often find a need for one in the present. There's only so much one can do with a drill press.
Maybe a separate TBN forum for machining - similar to the one for welding - would kick start some discussions.
When I got my bench mill I had to use my drill press to modify it for longer quill travel -- let it move upward 0.6" further.
...Dont know why related topics couldnt handle it along with post title. Forum proliferation is huge.
larry
I didn't intend to steal this thread. My apologies to the OP.
-dennis
Don't be silly, that's what we're all here for..
Anybody know a rule of thumb for how much you can hog out at one cut? Is it as long as the chip size is right, you can take as much as the power will allow?
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
