Rotary Cutter Whats there to a round back or squared back bushhog
   / Whats there to a round back or squared back bushhog #1
joulian
Member
I was just looking through a catalog and it had a round back and traditional "squared" off one ... whats the difference and pros and cons?
   / Whats there to a round back or squared back bushhog #2
Round ones miss more things (trees, fences) when turning - thus, more maneuverable.
Square decks are cheaper to manufacture and hit more things in a turn.
I think that is what you mean. A photo/link or two would help.
   / Whats there to a round back or squared back bushhog #3
I've had both and one subtle difference is that when mowing in reverse, the round back has more of a tendency to push tall weeds off to the side where they may or may not get cut. The square back does a better job guiding them under the deck. That said, I trim around a lot of trees and if stuff isn't too tall, I can trim closer with the round back.
   / Whats there to a round back or squared back bushhog #4
If you look under the square ones, you'll see a piece of curved metal welded to make it round on the inside. I have a 5 ft bushhog brand that I accidentally backed over a stump with and broke the curved metal piece underneath. I continued to mow, but it did not mow well at all. I had it welded it back in and was back in business mowing like normal. For whatever reason, the back really needs to be curved (one way or the other) to cut properly.
I should also add a disclaimer that this is not a heavy duty bushhog, there is no way it would cut through a 2 inch sapling.
   / Whats there to a round back or squared back bushhog #5
Not all SQ back have such deflector in the rear. My old Ford sq back is just open on the back. never had anything there.
The old sq back ones (with no deflector) will cut much like a discbine. they really only cut the grass once before pileing it up on the left side of the hog. So when i get done mowing it looks like ive raked my pasture into rows already.
mine will cut down 2" saplings, ive done it no probs.
2023 Load Trailer (A55787)
2023 Load Trailer...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED PABREAK GB232 - 84" HYD GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
UNUSED FUTURE HYD 12" AUGUER (A57193)
UNUSED FUTURE HYD...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
