Do you guys want to talk machining here?
   / Do you guys want to talk machining here? #11
Maybe a separate TBN forum for machining - similar to the one for welding - would kick start some discussions.
Very Good idea..!!.....:thumbsup:
   / Do you guys want to talk machining here? #12
I'll second that. I purchased a small 3/4hp used milling machine a few years ago but use it mainly as a drill press. I have a very similar rotary table , which came with my mill but have yet to use it. Friends have been dropping off a number of end mills, measuring tools and other milling gadgets. It would be nice to follow a few projects here to learn more about machining.
   / Do you guys want to talk machining here? #13
What do you say, Muhammad?
A dedicated forum for machining would open up a whole new world of discussion, attract new members as well as possible new advertising/site sponsorship revenue possibilities ...
To steal an old ad pitch from Honda:
You meet the nicest people on TBN!
-Jim
   / Do you guys want to talk machining here? #14
-Jim
i remember this idea being hashed around a year or so ago here. i believe the general consensus was that the welding section was also for other types of fabrication and tools too. the general idea being that this is a tractor related site and not a dedicated fabrication site.
I have like zero exp. with making metal shavings, but I was under my truck this weekend and spotted a nasty groove in one of my brake rotors... it kind of made me smile.. :laughing:
   / Do you guys want to talk machining here? #17
About the only time I ever used my rotary table, I made a new torch mounting bracket for my machine plasma torch. I needed a radius slot, (you can barely see it in this picture). Wow I never dreamed machinist have to have such eye to hand coordination! :confused2:
   / Do you guys want to talk machining here? #18
Here's one of my rotab's put to a different task....can you see it?
Just add 90vdc vari-motor w/speed reducer, frame and spare old 12" lathe chuck
welding positioner?
Nice job on the steam? engine Troutsqueezer!
6-Band Wooden Barrel (A55853)
6-Band Wooden...
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
2020 BOBCAT E35 EXCAVATOR (A52707)
2020 BOBCAT E35...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2023 Kubota KX057-5 Compact Excavator (A55315)
2023 Kubota...
