3-Point Hitch L-series Jerky 3PH - Jeff's homebrew repair.
   / L-series Jerky 3PH - Jeff's homebrew repair. #41
Any longer term updates to this modification?? Specifically, the neutral or back pressure question/measurement. Still happy with the mod after more use??
An interested owner.
thanks
Wxman
   / L-series Jerky 3PH - Jeff's homebrew repair. #42
Bump.
This looks like a reasonable fix that would add my tractor's usefulness if the consensus was it wouldn't cause other damage down the road.
Anyone around with more information on the flow control valve modification??
Thanks
Wxman
   / L-series Jerky 3PH - Jeff's homebrew repair. #43
Unfortunatally, I think jeff is the only one who did it.
And it appears he hasnt logged on for over a month now???
Try sending him a PM, he might have e-mail notification for that.:thumbsup:
   / L-series Jerky 3PH - Jeff's homebrew repair. #44
Anybody else give this fix a whirl? I PM'd jeff, but haven't got a response on from him. I have a L3800 I'd like to try this on, but i was just curious if there have been any negative feedback on it.
   / L-series Jerky 3PH - Jeff's homebrew repair. #45
I'm sorely tempted to just go ahead and do it.
Would be nice to have a parts list so I don't have to reinvent the wheel....
   / L-series Jerky 3PH - Jeff's homebrew repair. #46
Just figured I'd add here, my L3800 is not jerky enough to worry about. :thumbsup:
   / L-series Jerky 3PH - Jeff's homebrew repair. #47
If you have the L3800, then you should still be under warranty. Take it back to the dealer and have them fix the problem. That's what I did with my L3200 and it's smooth as butter..
   / L-series Jerky 3PH - Jeff's homebrew repair. #48
Just got an L3200HST and it is not jerky at all. Not sure if there was a modification done by the dealer (Barlow's - absolutely great to deal with) or it came this way but there is no jerk in it what so ever.
   / L-series Jerky 3PH - Jeff's homebrew repair. #49
That would be good to see, could you post a video of it going up *really* slowly? :thumbsup:
   / L-series Jerky 3PH - Jeff's homebrew repair. #50
I'd like to see that video, too.
I have an L3200hst, and with the landpride RCR1860 cutter attached it's very jerky when lifting slowly.
From all the attempts to fix or adjust posted on this site, I have come to the conclusion it is a design problem that Kubota can't fix.
Adjusting the 3pt valve to smooth causes other issues when using the loader.
I think Jeff's flow control valve is the only "fix" that might actually work.
Deere 335P (A53317)
Deere 335P (A53317)
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
TANK MANIFOLD (A55745)
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
