Do you guys want to talk machining here?
   / Do you guys want to talk machining here? #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
or rather stick:p to welding?
   / Do you guys want to talk machining here? #2
I'm sure many folks with tractors might also have some machining capability.
otoh, the machining forums that do exist are not terribly busy with the exception of PM.
did you buy the rotab and tail-stock for a specific project? care to share?
   / Do you guys want to talk machining here? #3
Sweet!
What are your plans for those?
   / Do you guys want to talk machining here? #4
I'd love to get my mitts on some machine tools, but lack the shop space and money
Sweet!
I'm trying to learn to think circular... :D
Got a dividing plate set with it, going to try a few practice runs this afternoon, no idea what specifically to make, maybe some spoked buggy wheels?
   / Do you guys want to talk machining here? #8
Looks like you are ready to start makin' chips! Having had access to a Bridgeport mill and a Southbend lathe in the past, I often find a need for one in the present. There's only so much one can do with a drill press.
Maybe a separate TBN forum for machining - similar to the one for welding - would kick start some discussions.
   / Do you guys want to talk machining here? #9
My son and I purchased a mill and lathe not long ago. The lathe hasn't arrived yet. He wants to get a rotary table and vice like you have in the photo. I've been reading the books and learning the calculations for cutting the metal types, cutter head speeds, tool design etc. The books are great but it really helps to have a machine to practice with. Great topic, thanks for bringing it up. What projects are you planning for the rotary table?
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
1515 (A57192)
1515 (A57192)
183 (A52705)
183 (A52705)
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
Freighliner Tender Truck (A55315)
Freighliner Tender...
