Do you guys think I'd be bogged down by this mower?
/ Do you guys think I'd be bogged down by this mower? #1
budcampo
CA
Kubota L3600
Hi All! I have a Kubota 3830. I have a opportunity at a Kuhn VKD 190 flail mower, here is a link VKD 190 - Shredder with horizontal axis - KUHN North America.com
Their site says minimum 50 pto hp... My tractor is hydrostatic, with 30 pto hp... I know this is probably a stupid question, but it's brand new for $5500:drool:
My tread is 73", and the mower total width is 81", & 1100lbs. It's a 2.5 hour round trip, so I figured I'd ask here before giving it a test run...
I'm sure somebody is going to say I would need a 50 hp tractor:( but it's such a bad *** mower, is there anyway this would work ok?
/ Do you guys think I'd be bogged down by this mower? #2
Does the one you're looking at come with the:
"For clean row spacing
Cut the grass close to the trees with a mowing disc.
This mechanical device moves round the trees for
clean maintenance without damaging the tree trunks
or vine stocks.
With its work/hydraulic transport positioning system,
this tool is very comfortable to use."
That would be sweet.
Strange that it only has a 15hp spread between Minimum and Maximum HP.
I've seen a CaseIH 1250 Grinder/Mixer being powered by IH 140. Though it was being fed slowly by my late FIL.
/ Do you guys think I'd be bogged down by this mower? #3
Hi All! I have a Kubota 3830. I have a opportunity at a Kuhn VKD 190 flail mower.........is there anyway this would work ok?
The 3830 will turn it, but in dense or tall grass you'll need to move slow or cut half-width. The good part is the strength and durability of the mower - it should hold up well. Who knows, you may like the flail so much you'll buy a bigger tractor for it :thumbsup:
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
