One thing that has been a problem is that in early BERTA owner's manuals, there was a recommendation to "remove the grass cutting blades at the top when using the plow in rocky soils"... and some folks actually read their manuals, and removed them. RESULT: with the "stationary" blade removed, not only is the gearbox casting completely exposed to impacts from rocks that might be picked up by the plowshares, but the extra strength that this stationary blade provided (it is a steel bar 5/16" thick and over 1" wide) to the gearbox "neck" is gone...hence, a very vulnerable gearbox, right when you need the strength (in rocky soils). I pointed out this discrepancy to BERTA when I was visiting their factory in 2010, and all subsequent manuals have been changed to show only removing the MOVING grass cutting blades (the ones on the top of the plow rotor). Any breakages of gearboxes as a result of this issue are replaceable by warranty...we have replaced two so far. If there are others out there, they have not been brought to my attention.---Joel at Earth Tools
