How often do you clean your tub?
   / How often do you clean your tub? #11
I have an Echo backpack blower that replaced the handheld I pained my back with for years. I don't remember when I bought it, but I'd guess 5 or 6 years ago....
Thanks for the tips! :thumbsup: My dad had an Echo back in the 60s/90s. I think my sister still has it. Pretty good quality stuff.
   / How often do you clean your tub? #12
I use Moss' leaf blower procedure after every mowing use. When changing oil
I layer up disposable shop towels in the bottom of the tub to get spillage. Then wipe up any oil that was missed. Hose it out once or twice a year whenever it sees mud.
I do that paper towel thing, too. I also crack the filter a half turn, then I slip a gallon zip lock back under and up around the filter, then remove it the rest of the way. Catches pretty much every drop and prevents spills.
I thank whoever on TBN told me of this tip several years ago! :thumbsup: :)
   / How often do you clean your tub? #13
Ok, that procedure will be used on my cars and trucks too. Wow, something so obvious....I never thunk of it before.:confused2:
   / How often do you clean your tub? #14
Yeah, it kills me when someone says "Why don't you try XXXXX next time?" and it is so simple I just stand there with my mouth open catching flies, often too stunned to slap my forehead with my palm! :dance1:
   / How often do you clean your tub? #17
Dear Carl,
After Sedgewick, I clean it whenever there is debris in the tub. (I check after every use.) I think the risk of ignition is too high with chaff and oil and fuel in the tub. I hand pick out all the big stuff, then blow out what I can and move to water. I always use detergent (dawn or simple green) on all oil spots in the tub after an oil change. That way, if I see a dirt patch, I know I have an oil weep from something and I can get on top of it while it is still just weeping, not spraying.
I powerwash it about every other month, or whenever I think I won't be able to see the weeps. Like MR, I get all of the solids out first, then use detergent and water. I haven't actively washed the tunnel, so I think I'll have a look see to figure out what I have been missing.
Love the ziplock idea; it sounds better than the little plastic tray that I've been using.
All the best,
Peter
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2024 Load Trailer (A56859)
2024 Load Trailer...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
SKID STEER ATTACHMENT HAMMER (A58216)
SKID STEER...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
