BX25 Mid PTO Pump or BUST
/ BX25 Mid PTO Pump or BUST
10-4
I am actually starting to get a grip on this stuff, well, the basics. THAT will be win no matter what.
I am waiting for driveshaft info / replies. Kubotas is ridiculously expensive.
It is just south of 400 Bux w/ tax and shipping!
I am sure they can be made and a profit for the maker for MUCH less. PLUS
I think Kubotas is 10 Spline on both ends. I would think I need to get that
made in; Kubota 10Spline 31/32" Quick Connect X 5/8"(or 1/2"?) Keyed.
Am I crazy for wanting a 4- Bolt mount? My thinking is it will be stronger
in case of undercarriage hits.
Will I be drawing the mount in AutoCAD or can you buy 4 bolt mounts so I can
fab it into submission? I am having a tough time finding them if there available, and made out of steel.
As of today, after checking "physically" with the part in my hand, I can now
make any driveshaft I want utilizing the MID PTO 10 spline on one end and
whatever I want on the other including the SAME, 10 spline x 10 spline if I
want!!! Muhahaha! I will be able to build shafts to "my" specs and not have
to buy Kubotas and Canabalize it, and for a LOT less then the stealers
almost $400.00 rape.
I have, in hand a quick release shaft end, connector that fits the BX25 MID
PTO, and others, 10 Spline ******* sized shaft and all others w/ the same
Mid PTO Shaft Dims. :licking:
Those parts are made out of Unobtainium, but guess who found a pile of
them, NOS!!! (Don't waste time on the computer lookin' :laughing:)
I hit that one clear out of the PARK! :cool2: NICE!
/ BX25 Mid PTO Pump or BUST #43
Looks like Artisan found the tractor parts black market.
/ BX25 Mid PTO Pump or BUST #44
Pictures or it didn't happen :D :laughing:.
Aaron Z
Too Funny! So I am now a liar, dealing in black market parts? NOT!
As far as my source, we will not be giving that up anytime soon, I assure
you, NOTHING "BlackMarket" nor GreyMarket happening here... :mad:
/ BX25 Mid PTO Pump or BUST #46
If that was directed at me, I was trying to be funny but forgot to use a smiley. Will add one now.
Aaron Z
/ BX25 Mid PTO Pump or BUST #47
Have you looked in to two stage high volume pumps. First stage gives big GPM at low psi then switches to lesser GPM at higher psi when load increases.
Surplus Center list one with 1st stage 28 GPM @ 650psi, 2nd stage 7.25 GPM @ 2500psi requiring 16HP Theirs is CW rotation, so you would need to find one with CCW rotation.
I am not sure how this would work powering a hydraulic motor, but it would work great on a cylinder for a log splitter. Lots of speed until the load got heavy then lots of psi to get the work done (only slower)
What size fittings were you seeking with long radius 90s? Probably too small, but my loader has the on the valve to hoses so the rear hoses can go over the front hoses without interfearance.
Danuser you here? (from the grapplomatic thread I invited him over here)
If so I am confused, you mean 10 GPM or just a little less will not spin one of your pumps? I thought the specs started at 6-GPM for hydraulic augers? Oh, and I am not looking
at hanging off the rear w/ an auger, seems to me augers are easier on the neck when hung from a FEL. If you look at my GrapplOmatic thread I am considering hanging an auger from the grapple cylinders TOP mount. So remove the grapple and use that top mount, "maybe" .
I have been having connectivity issues w/ the TBN website only...hence
my absence...
I think I have settled on a pump. Looks like we might be able to squeeze
10gpm out of the given HP and rpms.
Thank you aaron, indeed I have been getting hit from all sides. Many would
love to see me win, seems like more want to see me flounder.
I have a pile of quick connect ends, enough for 7 machines and I know
where there are more of the 10 Spline quick connect ends only to turn into
any shaft I want. Money is what it is, nothing cheap about hydraulics nor
keeping the mortgage current, an elderly parent and the business floating all
at once. Hopefully I can buy the pump next week. It is not the cheapest, but
I tend to try to use quality parts anywho. The Surplus center has cheap
stuff but once there sold out that is it, it is truely a "surplus" supply center.
I have to get a 10 gallon tank above the pump and I have an idea to almost
make it disappear. I have CAD files for the pump and I started drawing a
reproducible bracket...one thing at a time...I think the biggest hurdles are
over, a connector for the mid pto shaft, pump and the
gumpsion to geter-done...:thumbsup:
Thanx Jery, I will look for Brand New as regularly stocked and I am
Not baggin' on SC I just seem to look at a widget one week and a few weeks
later it is gone...so to buy there and expect to go back and or send a friend
and expect to get the same is a gamble is all. Thanx for the info though...
It's all good...
NOTE: I just went and looked. I could not find one part labeled:
NEW
NEW TAKE OFF
REMOVED FROM SERVICE
BRAND NEW
PS I Just called, and the gal didn't know either,
and she said she had never seen anything labeled as such either.
I guess my point is, is "Parts are here today, gone tomorrow" . Caveat Emptor.
Quote;
Our surplus products are usually one time purchase at prices well below
normal. Quantities are limited to what we have on hand.
We describe our products as follows:
New - products that have never been installed or used
New Take-Offs - items removed from unused equipment
Removed From Service - used products in good working condition
Brand New - non-surplus products we regularly stock that are purchased
directly from the manufacturer
/ BX25 Mid PTO Pump or BUST #53
I have dealt with the Surplus Center for nigh on 15 years. When I buy a "Brand New" item it is something they either stock on a regular basis or have made especially for them and brand it. The "other" stuff may be as you describe. I have purchased both in that time frame and have not been disappointed.
I have noticed that the prices on "Brand New" items are escalating, sign of the times I guess.
/ BX25 Mid PTO Pump or BUST #54
Just so you know, I hope you WIN :thumbsup: Hit a home run!
/ BX25 Mid PTO Pump or BUST #55
Size your pump to provide a flow of 12-14gpm as this will allow you to run standard attachments made for walk behind skid steers and track loaders such as the Toro Dingo or Bobcat MT55. It opens up a whole world of standard tools from post hole augers, to cement mixers, brooms, blowers, tillers, pumps, saws, stump grinders and the list goes on. Many of these are available used or from a rental yard by the day.
You could adjust your pressure relief to protect the motor from stalling. You also don't have to limit your system so that it can't stall the motor, that is only one way to configure a system to run attachments. Many systems on the market today, such as mower or tillers, do not protect the motor from stalling, that is up to the operator.
Mr. HE:cool:
HA! OK Zebra5...thank you ...
hddnis my research says I do not have the HP to do that. I guess it is what it is.
I can get maybe 10GPM or so w/ the HP and RPMs I have. Not to fret, THAT
will do a lot. The tractor itself only puts out a lil over 6GPM. So if I can build a
stand alone system at 10 a guy can do a lot.
Ill focus on my shaft, my mounting and after that things kind of get dictated
by what exacty do you want to run, I think. I believe if I have a 10GPM
system and if I run lets say a 5.3GPM T-Post driver, I have 4.7 GPM pushing
past that relief right? So that will heat up the oil real fast right? Gawd I have a lot to learn...
/ BX25 Mid PTO Pump or BUST #57
Not exactly, as the fluid not used is just going to tank.
You could also limit the GPM's by the tractor rpm.
My Power-Trac, uses a valve like this to supply the fluid to the hyd motor.
Surplus Center - 1/2 NPT HYD FLOW CONTROL VALVE W/RELIEF RDRS150-16
http://www.surpluscenter.com/adspecs/AS9-064-50.pdf
/ BX25 Mid PTO Pump or BUST #58
You do have the power to flow more than 10gpm.
At fixed HP, as pressure goes up flow goes down. Conversely as flow goes up pressure goes down. Only fixed number is your HP in this case.
Most hydraulic systems use between 2000-3000psi. Some use much less, some much more.
To explain my suggestion a little better. Go for a flow rate of 12-14 gpm at full throttle. You will want a pressure relief in the system of no more than 3000psi to protect hoses, pump, fittings, etc. (for your application)
Your available HP will not give you full flow (12-14gpm) at relief pressure (3000psi) What I'm saying is that you don't have to limit your flow based on HP. The HP is the limit of the work you can get from your tractor, not a limit of either flow or pressure.
The only reason to build within those limits is stall protection. You don't have to build in stall protection. If you want to have that feature you can adjust your relief pressure, you will still be getting the full working potential of your horsepower (minus system efficiency derating).
Anyway, just a friendly suggestion, with the goal of giving you more options. I'll be following your project with interest.
Mr. HE:cool:
/ BX25 Mid PTO Pump or BUST #59
I like hddnis's suggestion. In other words, you size your pump to put out 12-14 gpm at full throttle and just get whatever pressure you get. Worst case scenario, you stall your engine and have to start it again. If you need something with less flow and higher pressure, you can tap into your tractor hydraulics that you already have onboard.
I think a key here is that you are designing a secondary hydraulics system to compliment what you already have. You should build it to do what you can't currently. The option to use a lot of the currently available skid steer type attachments is a good option to have. It's all about versatility. Few of these attachments are going to require the full pressure, but you can't really run them without the proper flow.
/ BX25 Mid PTO Pump or BUST #60
The guy building the BX skidplates was also selling mid mount pumps... Bro Tek is in Canada and is/was very active here on TBN.
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
25026SFL (A61569)
25026SFL (A61569)
