A Sad Reminder
/ A Sad Reminder #11
For me life is just to short and I love everyday too much to risk it... thats why there are tire shops. If they don't take air themselves I either call the farm service truck or take it in myself.
/ A Sad Reminder #12
Mace, Do YOU really have one of those Beadpoper inflator cans???That is the first one I have seen?
/ A Sad Reminder #13
It boggles the mind why professional people wouldn't use the proper equipment to seat a bead on recalcitrant tires.
Wow, that's the biggest can of Ether I have ever seen. I didn't realize it took so much.
Relax, I am kidding.
/ A Sad Reminder #14
I have 3 of these cheater tanks and they work good on some things like new tires that stand up when the machine is jacked up. ALot of tires like trailer tires or a spare truck thats not moved and has a flat the tire is so wrinkled that it wont seat. THey also wont seat a some stiff new tires. I cant seat my skid steer tires with the air tank as they have rimguard beads on them.
One reason I use ether is that when a truck gets a flat onthe side of the road and here we dont have any shoulders. I can park a service truck run an air line to the tire and then ether it and be gone till the truck can get to a better spot.
With the CHeater tank your about 2 to 3 feet further out in the road. I had to use either this morning on a truck tire. The tire wouldnt take with the air soe we gave it a small squirt.
/ A Sad Reminder #15
Gas works too. Don't recommend it but... When you're on a trail an far from home you do what you got to. Only had a small hand pump and some plugs. That doesn't help when your 4 wheeler tire is off bead. Oh well I got home;-)
/ A Sad Reminder #16
I agree, 2 of the cheetas wont seat my stiff skidd steer tires but a little gas poured around the rim will. I am not recomending it though.
/ A Sad Reminder #17
Nope! I have a manual tire machine (bought it when I started Stock Car racing back in mid 80s) but I usually don't have trouble getting tire beads to seat. If I can't work them onto the bead, I will simply take them off again and spread them apart using four 1 X 2 wood slats cut to length. After leaving them spread like that for a day or two, they take a set and the beads are pushing against the seats when I put them on again. I realize not everybody will have the luxury of waiting like that but if you do, it does work quite well.
/ A Sad Reminder #19
I see nothing wrong with trying this! As long as: No people are exposed to what you should assume will be a humongous explosion, & you are completely OK with what you should assume will be the destruction of your tire/rim & maybe some other nearby stuff.
Meet that, & you can go for it IMO :thumbsup:
/ A Sad Reminder #20
Plus the amusement of watching the wheel hop, pop or thump off the ground..But starting fluid takes a small amount..It is not nearly as dangerous as putting a tire on the old 3 piece wheels for duals? Having to either sit in the wheel or shoving it under a jeep to inflate..We Finally recieved the safety cage for inflation?I believe they finally stopped making those wheels?
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
Freighliner Tender Truck (A61307)
Freighliner Tender...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Adams 16T Tender Body (A61307)
Adams 16T Tender...
