3PT squeals on partial raising
/ 3PT squeals on partial raising #1
MoreCowbell
Clayton, NC
Kubota BX2350
Here is something that has always bugged me about my Kubota BX2350. When there is any kind of weight attached to my 3PT, it squeals when I try to slowly raise it by partially raising the lever. It sounds like the relief valve making the noise. The issue exists regardless of HST temperature.
When I fully pull the lever up, it works fine. It raises the attachment vigorously with no squealing.
I assume that this is due to nuances in the way the spool valve is switching oil flow as it transitions between the neutral and raise positions. The FEL works fine with this type of usage so I am wondering why the 3PT acts like this. Is this just poor spool valve design?
If anything, I would have expected it to be the opposite. My understanding of this machine is that the 3PT is the last of the line in the hydraulic circuit and, unlike the FEL valves, does not have to handle power-beyond flow. It would seem to be a simpler design and and easier one to get right.
Thanks.
Responding to my own post. Even though the 3PT is the last in line in the hydraulic circuit, I suppose it still does need to handle the flow of oil through the valve even though no other valves are beyond it.
Still though, I think this is a design issue of the spool valve. However, I have little hydraulic knowledge other than what I read here and there.
/ 3PT squeals on partial raising #3
You can determine if the screech is from the relief valve by using a gage in the system. If it is relieving, it will read relief pressure.
It should only relieve when the load exceeds the lifting capacity.
If you put 100 lbs on the 3pt, the relief should not go off until you raise it all the way.
/ 3PT squeals on partial raising #4
my BX24 3pt also makes that noise, only when lifting slowly, so it's not just your machine. I mostly use the 3pt just for my snow blower, so it's really not much of an issue.
Pete
/ 3PT squeals on partial raising #5
This is normal on the BX. Since this is an open center machine all the flow must go somewhere. When feathering the control to lift slowly, the excess flow is going across the relief valve.
/ 3PT squeals on partial raising #6
Can one of you put a gage in the hyd system and verify that you have relief pressure on the gage when slowly lifting.
Just curious.
Thanks for the quick replies everyone. J J, I'd sure like to get that pressure reading. However, I don't have a gauge for this so I would need to pick one up first.
I found 80195 5000 Psi Pressure Gauge at AgriSupply. It is pretty inexpensive. Is this what I would need? Any other suggestions on what to get - flexible extension hose maybe?
Thanks again.
/ 3PT squeals on partial raising #8
A hyd gage test set like this should only cost about $30.
The gage should run about $10 to $15, plus the 1/4 in QD set, short hose , and a tee.
/ 3PT squeals on partial raising #9
Interesting ... our B5100 seems to screech/squeal like a pig when lifting anything, even if it's just the lift arms with nothing attached. I had been thinking cavitation, which I would want to nip in the bud before it caused any damage. Maybe this is normal?
J J, thanks for the tip. I'll get a hold of a gauge. I will just need to figure out where to tap into my hydraulic system. I guess that is not really a general hydraulics question since that would be specific to each machine.
I have quick disconnects for my FEL, but since everything else still works without the FEL attached, it seems like those connections are not in the power beyond circuit, but maybe behind some kind of priority valve. I'll take a look and see where I can tap in.
Baby Grand, if your relief valve is kicking in when raising the 3PT without a load, that does sound like something is wrong. Here's a question: if you loosen the dial that controls the 3PT lowering speed does that help? If so, maybe the 1-way check valve that runs parallel to the dial valve is stuck and the raise flow is being forced past the dial valve.
/ 3PT squeals on partial raising #11
If you want to monitor the complete hyd system, install the gage or a QD coupler at the IN port of the FEL valve in a tee. Then any hyd being operated will reflect the pressure used, on the gage.
/ 3PT squeals on partial raising #12
<snip>
Thanks, MoreCowbell, I'll check and see if I have a lift speed control.
J_J,
The lines that run from the HST to the FEL valve are all rigid pipe. I don't think it would be easy to tee into that without bending the tubing.
Instead of that, I'm thinking that I can rig up a bypass hose that I can use to connect between the two quick connects for the FEL lift cylinders, then tee into that. To do the pressure test I would just need to hold the FEL joystick down or up. Does that make sense to you?
Thanks again for your help.
-Rob
/ 3PT squeals on partial raising #14
By plugging into the FEL QD, you only test the FEL relief.
If you install a QD in the IN port of the FEL in a tee, you test the tractor hyd circuit. Any valve that is activated.
/ 3PT squeals on partial raising #15
Basically, there are two types of 3P hydraulic systems of a tractor.
One of them is a type which the height of 3P can be controlled by the position of the control lever.
It is called "feed back type"or "position control type" and the valve is linked by a feedback rod from 3P.
Almost "common" tractor has such system.
On the other hand, there is a more simple system.
It does not have feed-back system, the valve has only three positions. up, down and neutral.
Most of sub-compact tractor has such system except of very few model.
I think it is normal that such a sound occurs when a lever is operated between neutral and a raising in order to raise 3P slowly ,since the valve of such a type does not have a "inching" zone.
Most valves for FEL have an inching function.
Even if its appearance is only an simple 3 position type.
I am not sure about BX2350's detail. For your information....
Thanks!
Hedge Posts (A65640)
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
