1984 MF 1010 bleeding the fuel line
   / 1984 MF 1010 bleeding the fuel line #1
jmcginn13
Pittsboro, NC
1984 MF 1010
I've just changed the fuel filter and now it won't start. I'm guessing I got air in the line. I've tried bleeding the line, but am having no luck. Am I missing something? I loosened the screws above the filter and cranked it, but no fuel comes out. The trap doesn't even completely fill. This is my first time doing this so I am little lost.
Thanks!
   / 1984 MF 1010 bleeding the fuel line #2
If you aren't getting fuel to the bowl make sure you have the fuel valve above the bowl set to on. Is there any possible way you installed the filter backwards. If it has a check valve in it, it will only work one way.
   / 1984 MF 1010 bleeding the fuel line #3
Yup the valve is on, or at least the handle is in the on position. I am suspicious that maybe the handle is stripped out and the ball is still closed. It was really stuck when I first closed it, but now is super loose and easy to open/close. If it is open shouldn't fuel flow into the trap by gravity alone?
I don't believe I could have gotten the filter in backwards. Its a simple paper filter with a rubber gasket on one side. Rubber gasket goes up right? :D
NAPA AUTO PARTS
Thanks
Oops I'm the OP, I accidentally signed up for a new account, but then found out what my old account was.
   / 1984 MF 1010 bleeding the fuel line #4
Good news, turns out the shutoff knob had broke. It has a set screw so I was able to pop it off and notice that metal nub that fits into the actual valve had broke off. So I used my screw driver to open the actual valve and reattached the knob and was off and running. Wonder if I can order just the knob :D
Another question, on the side of the fuel injector there is a big adjustable bolt, maybe 2 inches long. I accidentally turned this during my bleed off attempts. I notice this has some impact on the idle. Is that the idle adjust or some sort of air intake valve? What is the proper method for adjusting it?
Thanks
   / 1984 MF 1010 bleeding the fuel line #5
Thanks
We may need a picture of this one, close up. I have a 1010, and both the owners manual and an ITG manual, so if you can post a pic, we may be able to advise.
2016 MACK TITAN TD713 (A51219)
2016 MACK TITAN...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
