Box Scraper What size bix blade?
/ What size bix blade? #1
rebelback
South Arkansas
2010 Case Farmall 45 HST
I have a 2010 Farmall 45 4wd that I'm looking to get a box blade for. It is a 6ft wide tractor. Should I look at getting a 6ft or 7ft wide box blade and why?
/ What size bix blade? #2
I have a 6ft medium duty weighs alittle over 600lbs boxblade.jpgand I can get a full load of dirt and sure fill it back there. I run a kubota 5040 4x4,and im happy with the 6ft,would you benefit any going to a 7ft? What will you be using it for? Do you have some in mind?
Initially it will be used to smooth out a bunch of skidder ruts left on our land when they cut timber prior to us owning the land. Other than that it will be used to maintain our drive and other odd and end projects where dirt moving and leveling will be needed.
/ What size bix blade? #4
Im gonna say a 6ft,cause you will probaly have the rippers set and I can say mine without rippers set,I have to run in 4x4 with a full load. If it was just a driveway I would say a 7ft.
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
2024 CATERPILLAR 279D3 SKID STEER (A65056)
2024 CATERPILLAR...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2009 PETERBILT 365(INOPERABLE) (A67714)
2009 PETERBILT...
2018 Ford F-250 Ext. Cab Pickup Truck (A66736)
2018 Ford F-250...
