Ford 1700 head cracked
/ Ford 1700 head cracked #1
Stoneconst
Xenia, ohio
Ford 1700
Hi, everyone. I have looked at this site and forum sence i bought a Ford 1700 off ebay for $2500. The tractor has. New paint and looks very good with 3047 hr. The engne runs and everything works as it should but there was a noise in the enging. I pulled the head and it is cracked all to pieces. There is a crack between the valves on both cylinders and running off at angles from all the valves. My questions is with this much welding and machining. Were can i find a good head at a good to fair price. Anyone have a good head for sale. There is people on this site that has 1700 tractors that have gret wisdom so any help is greatful thank you
/ Ford 1700 head cracked #2
Thanks for the pics, but yes i talked to my head guy that has done other machining for other projects. The cracks run deep any can be fixed. ($12
00.00 or so complete). I was hoping that i might be able to come up with a bare casting that is good.
I noticed in the pic of your top of engine block that yours is like mine. If you look at the water jacket openings some are not open at all but are inline with some of the ones on the head. Sence heat rises and the flow of coolent can not move thru the closed off jackets i think it is creating hot spots on or in the head. I wonder if these are drilled out so the coolent can flow through all the ports in the block and up through all the ports in the head it would cool better. It is only a thought. First I need to find a head at a price that makes me want to fix the tractor an not part it out.
/ Ford 1700 head cracked #4
Did you say $1200.00 to fix the head? My machine work cost $240.00 and that was boring 2 cylinders, installing all press fit bearings, freeze plugs, and a head job to include crack repair.
Your head may have more cracks and may require welding instead of pinning but that still sounds high priced.
Russell
/ Ford 1700 head cracked #5
To correctly (so it won't self destruct quickly) repair cast iron, you must use the correct weld AND the correct thermal cycle with heating the part up before, weld it hot, hold it hot and slow slow slowly cool it down to keep it from hardening up. That can easily cost 150 to 200 per crack and is why it's typically not cost effective to repair more than one crack.
Search the tractor salvage yards (found by googling) and get a replacement. I wouldn't waste a second on a head with multiple cracks.
UNVERFERTH 2755 SEED RUNNER (A64278)
UNVERFERTH 2755...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2017 HYSTER H60FT STRAGHIT MAST FORKLIFT (A63276)
2017 HYSTER H60FT...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
2021 SANY SY26U EXCAVATOR (A63276)
2021 SANY SY26U...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
