UNDERCOAT TRAILER:WINTER SALT?
/ UNDERCOAT TRAILER:WINTER SALT? #1
escavader
western maine
bx-23 ,
Should i undercoat my 2 year old tandem,with rubberized undercoating before winter.The calcium and salt can take its toll on stuff up here in MAINE.Is there any reason not to?I just thought it might protect it,although i try not to use it.Someone always needs a driveway pushed back etc and i gotta haul the tractor.Napas got it on sale for 3 bucks,thought i might be able to do it good for a twenty.It is possible to be some spotty slight surface rust underneath,im not sure,go right over it?Good idea?bad idea?other product thats better?THANKS AHEAD
ALAN
/ UNDERCOAT TRAILER:WINTER SALT? #2
Please note this is not the voice of knowledge:
What I would suggest is sand blasting to solid metal as much as is possible. Then painting with a rust retarding type paint followed by an overcoat of regular paint.
For the undercoating use roofing tar/sealant [ that ugly black sticky stuff ] mixed 50/50 with varsol. Use the sand blasting gun to spray it on. Several coats may be advisable. [ expect to discard any clothing used in this process.]
The roofing tar is much cheaper.
/ UNDERCOAT TRAILER:WINTER SALT? #3
Having used some roof coating from Lowes recently I will agree with you.
Varsol is Mineral Spirit's here in the states.
Using the Sand Blasting gun may not be the best way to apply it. May be a bigger cleanup job than the actual apply. I applied it with a wide putty knife. Found that it wanted to drip down even in its thick state. Turning trailer upside down may make it work better.
I have used the stuff they sell at local auto stores with great success. It will not drip as much. Make sure area being coated is clean.
/ UNDERCOAT TRAILER:WINTER SALT? #4
The roofing tar works well if you keep it from hardening and cracking in the future. If it does that, the water and salt get into the cracks and collect between the coating and the metal and it ends up rusting even faster than it would have without the coating. At least that's my experience. What I do to keep the coating from hardening is to oil spray it every fall. Which reminds me, I better get at that soon :( (It's a messy job.)
/ UNDERCOAT TRAILER:WINTER SALT? #5
My H&H trailer came with undercoat from the factory. My Appalachian gooseneck frame was painted. Each summer I pick up a few cans of rubberized spray on undercoat and give the trailer frames a quick touch up. All of my area roads turn white from the salt thrown down each winter. They don't call Syracuse the salt city for nothing. Anything I can do to resist the salt attack on metal helps.
/ UNDERCOAT TRAILER:WINTER SALT? #6
I undercoated the metal frame of my Snow Trac (Swedish made snow tractor pictured in my avatar) with a 2 part epoxy that is very similar to "Rhino Liner" The stuff is amazine, takes an impact and protects the underside of the the machine. If you've got a reasonable size compressor, and really want to do a job that would be durable long term, I'd recommend it. Cost to do the underside of a trailer would probably be $75.
/ UNDERCOAT TRAILER:WINTER SALT? #7
What was the name of the two part epoxy and where can you buy it??? I just picked up a new equipment trailer and would like to get something on the bottom of it..Thanks..
/ UNDERCOAT TRAILER:WINTER SALT? #8
Do some research on coal tar eoxy. I used to be an industrial painter 20 years ago and used it on stuff that would be submerged in salt water.
Sewage treatment plants would want it applied to the rakes that were used for raking foreign objects out of the sewage.
After it cured, it would look like a rubber inner tube had been shrink wrapped over the entire piece.
You can spray it, roll it or brush it on if you like.
HELLO,
I did my trailer today .It took 7 cans!!! looks great under there. Note ...wear old clothes!!!I did it on a tarp...dont do it on your cement floor,cause it will get all over it.They didnt have enough of one brand ,at NAPA,so i used 3-m and also duplicolor brand the latter kind sprayed much better,had a better nozzle thats why.It was also cheaper.iM SITTING HERE ON THE COMPUTER AND IM FINDING GOBS IN MY HAIR!!Wear A WINTER HAT!! Got to hit the shower now,but i bet it wont wash out,it took gas to clean the hands.
ALAN
/ UNDERCOAT TRAILER:WINTER SALT? #10
Sorry to dig this old one up, but I was wondering how the undercoat did.
The horror story you hear about undercoat is that it traps water next to the steel and actually makes the rusting worse.
Thanks!
To be honest id forgot id even done it.It didnt stay on too good .I try to avoid using the trailer in the winter now ,but every spring i crawl under with paint brush and tub of motor oil and slap it on.I have 0 rust on this trailer and its now 7 years old.Iuse it weekly in the summer hauling atvs all over the state,or hauling the tractor.Im now a firm belever in the old method of slap motor oil to it.Itry to park it on a disposable piece of plastic before i do.This year i need to replace the deck boards,so i wont be crawling.
ALAN
/ UNDERCOAT TRAILER:WINTER SALT? #12
ALAN
exactly! i am glad to see some one else with "experience" see that used oil (if done responsibly) is a great way to preserve things against rust. i will "paint" my entire trailer with used oil each fall. use a wagner power stainer to spray the underneath too. run it up and down a dusty dirt road to "lock" the oil on better (looks dirty, but will NOT rust, dirt will not ruin it, but rust will, and if want to clean it off and make it look pretty again, just pressure wash it and use an old scrub brush). still beads off water in most areas after winter. i do the same thing to my trucks each fall (just the wagner on the frames underneath). it beads off water a year later in most areas. not the wheel wells though as they seem to get the most action. keep it away from the exhaust and brake systems and i have never had a problem. i never tried the rino lining stuff as i believed it would develope cracks and make the problem worse (as was stated). besides it adds extra weight. not much i am sure but why add any. the used oil works for me and i will keep doing it.
Id just wouldnt want to be the joker who is tailgating me in the first rainstorm:DMight be a little residue on his wind sheild
/ UNDERCOAT TRAILER:WINTER SALT? #14
Zombie thread! :D
/ UNDERCOAT TRAILER:WINTER SALT? #15
Thanks!
Yes that's true, I have seen examples. Now days they seem to spray a waxy oil or more like a grease like thick oil.
Being in aviation I discovered that raw linseed oil was an accepted method to treat aircraft steel tubing. I tried it on a car I once owned and it did a fine job.
Raw linseed oil when heated gets thin enough to spray and gells as it cools.
It has an affinity for rust, so much so that a few drops on a rusty piece will get sucked to impressive distances.
Sort of ink on a blotter (for those that remember fountain pens, LOL)
On the underside of a trailer I suspect that due to roadway conditions any system will want an annual re-coating. Driving at even normal speeds the sucked up grit acts like actual sand blasting.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
207278 (A52708)
207278 (A52708)
2016 Toyota Camry Sedan (A61569)
2016 Toyota Camry...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
2015 C&M TRAILER 14 ENCLOSED CARGO TRAILER (A60736)
2015 C&M TRAILER...
