BX25 Mid PTO Pump or BUST
/ BX25 Mid PTO Pump or BUST #1
Artisan
Monrovia, California
Kubota BX25
So there it is, a perfectly good, brand new, unused mid pto on my BX25
that I am seeking to put to work, somehow. :D Don't know what for yet,
maybe an Auger, maybe a blender, time will tell.
The BX25's mid-pto specs are up to 2500 RPM and the shaft, well, I don't
know the exact call out for it but it is something like a 1" 10 spline? If
anyone knows please chime in. PTO HP @ 3200RPM = 17.7 . I never tach out
my tractor, usually around 2500 or so.
Does anyone know of this being done on a BX25? Basically if anyone has
done anything other than use it for a MMM I would like to see what you
konjered up.
I found a company building a 2000-2500 mid mount pump and I have a
post into them looking to see if that have a BX25 solution, I will post up
when I find out.
I'll never have a MMM and I want to find a use for the Mid PTO. The BX25
does not have huge GPM ratings and a nice compact pump under there
might be extra nice for a myraid of items. I find it hard to believe no
manufacturer is not already making it.
/ BX25 Mid PTO Pump or BUST #2
If there is little demand for a pump like that, they probably will not make one.
You could be the first to come up with a working solution. You will have to find the right adapter between the 1 in shaft and the hyd pump, maybe a lovejoy connection setup, and a way to brace the pump.
If that mid PTO motor can run at 2500 rpm, then you can match up a hyd pump that can develop the pressure and use the available HP to produce a certain GPM.
/ BX25 Mid PTO Pump or BUST #3
Kind of like this one? :)
Bruce
/ BX25 Mid PTO Pump or BUST #4
Here is a few quick thoughts. A high pressure piston pump run off of the tractor res. Low flow but high pressure so as not to heat up the fluid in the tractor. Good for a snow blower or the like, not so good for a splitter or any volume related app. Pump would be easy to mount under the tractor and direct drive with just a coupler. A standard gear pump will be higher volume but cheaper, I am not comfortable pulling 20+ gpm from the tractors res. So back to a 3 point res/pump combo and gearing up a drive for a gear pump. That will get me 25gpm at 2500psi and no heating issues or intermixing of fluids. I do Hydraulics for a living and this seems to be the best all around option. So I guess like everything else it depends on what you want to do. CJ
/ BX25 Mid PTO Pump or BUST #5
The BX25 only has 23 HP, and therefore can only support a 3000 psi, 11 GPM hyd pump , with nothing else moving.
Bruce I live somewhat close to GLAMIS CA, and we have gone there a lot,
I have seen a LOT of variations on the blender, yours is great too! :laughing:
I think the funniest was one made w/ some motorcycle handlebars utilizing
the throttle ...:D
Bruce
It's hard to believe no one has done it. There is a 10 Spline to 6 Spline
Adaptor available. I am looking at all angles. I see there is a driveshaft assembly
that goes to the front to run a blower and a sweeper. THAT might be
a ticket as well, hang a pump off that out front, up high, so as not
to loose ground clearance. Gawd I would love to fall into those parts
for a song so I could "play" w/ them.
I actually found a Middle Mounted Hydraulic Pump on a tractor, I wrote the
people and I await a reply. I am trying to absorb this stuff from afar, it is
hard cause I have never seen so many of these parts, I am gonna stick with
it for a while...
If the Mid PTO is used, were down to 17.7HP at 3200rpm too. I want to
try to keep my tractor running around 25-2700 and not full throttle but
still that should produce some "healthier" GPM's I thunk.
/ BX25 Mid PTO Pump or BUST #9
That will give you about 8.5 GPM at 3000 psi, and the pump would run at 3200 rpm and have a displacement of .6 cu in.
All this using 17 HP
/ BX25 Mid PTO Pump or BUST #10
the throttle ...:D
I used to go there a lot in the 60's and 70's. That was before blenders, and most dune buggies were cut-down and shortened American sedans with widened wheels, like these photos I found online.
http://archhalljr.com/yahoo_site_admin/assets/images/eegah.316135804_large.JPG
http://dstults.com/cars/50ford.jpg
Bruce
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2019 CATERPILLAR 420F2 IT BACKHOE (A59823)
2019 CATERPILLAR...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
429981 (A61165)
429981 (A61165)
CASE IH MAXXUM 115 TRACTOR (A62130)
CASE IH MAXXUM 115...
