portable blaster from harbor freight.
   / portable blaster from harbor freight. #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
HF has their portable blaster on sale for 24$ lil grey pot with a molde din handle.. carries a few poubds of media.. says it will blast sand, beads or steel.. but don't mention soda.. etc.
has the 15' air line and nozzle.. you just provide air compressor. etc.
i'm not a fan of sand blasting as it gets everywhere and can deform thin metal.. but will admit once in a blue moon I do have a small part that could use blasting to save hand work.
I would need it so infrequently that even the 99$ benchtop cabinet would be too much and I'd just pass and keep using a wire wheel. but 24$? I'd go that for a 1-2x per year use on a hand sized part that I might need..
opinions.. anyone got one?
soundguy
   / portable blaster from harbor freight. #2
Are you asking about the spot blaster? It is basically a blow gun with a plastic media hopper on the top. If so, I have one and it works well for fine media.
this one has a hopper the size of 2 1g ontainers on top of each other, and then a 15' hose. it's not the blaster with hopper on gun... but would look at that too if cheap.
   / portable blaster from harbor freight. #4
I don't really know which one at HF you are referring to, but for a small blaster all you really need is just the gun. For a square foot or so what I do is put the media in 5 gallon bucket and put the suction tube in the bucket - it works. Sometimes I'll just put the suction hose in the bag itself.
For larger areas, the suggestion about renting a tow behind compressor is a good idea. Blasters use a lot of air.
If I was going to do much blasting I'd get a pressurized media tank. It's on my list of things to get, but I have no idea if it will work as well as I think it should.
   / portable blaster from harbor freight. #5
Oh yeah...pressure pots are the cats meow. A siphon gun and a bucket wouldnt be a bad choice for you SG. Pretty versitile and inexpensive. I think my spot blaster from HF was about 20 dollars. You would spend more time filling a spot blaster, but you have to drag a bucket and hose if you use a siphon gun. Tradeoffs???
   / portable blaster from harbor freight. #6
Chris....
Save your money and get a small pressure pot blaster from TSC for a hundred bucks. You live in humid Florida...... Media don't gravity flow well there.
Hundred bucks is a fifth of a gun......:laughing:
   / portable blaster from harbor freight. #7
Should be able to even blow "talc" with that, water separator/filter will be the most important addition and a good one can get expensive. I have used cheaper ones in the $50-$75 that did good, just had to watch runtime and conditions.
When needed for work or hobby, I pull out the 175 cfm Leroi and the 300# p pot, man you know your dangerous when that thing is blasting:laughing:
My small 80# pot was made in 1948 and works like a dream, as long as the moisture is kept out. Seems the smaller the unit, the quicker it waters down.
   / portable blaster from harbor freight. #8
since nobody has answered your question, i found this video of the unit and it looks to be a great buy for 24 bucks does the job:thumbsup:
[ame=http://www.youtube.com/watch?v=dEb4soCe1RI]My new Harbor Freight portable sand blaster.wmv - YouTube[/ame]
   / portable blaster from harbor freight. #9
I didn't know he asked a question??Only asked for Opinions! Opinions are FREE:)
SHOPBUILT T/A BUMPER PULL TRAILER (A52708)
SHOPBUILT T/A...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Kenworth T880...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
Flatbed Truck (A55973)
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
