Dump trailers
   / Dump trailers #11
I am currently on my second dumping trailer which is a Moritz 7'x14' 14,000 lb (www.moritzint.com) and they are located in Ohio with dealers in USA and Canadian locations.
I am located in Canada about an hour north of Toronto and my first dumper was a JDJ manufactured up here. I got a lot of work out of it but our winter climate and salt took their toll on it. The JDJ was manufactured completely with hollow tubing which not only corroded from the outside but also from the inside. I would avoid any trailer which is manufactured completely out of closed box tubing for this reason as after six years there was a lot of rot in my JDJ. The entire box of the Moritz is constructed with C-channel steel so their are no hidden spots for corrosion to begin. I also take the Moritz in with my truck when I get my annual rust proofing sprayed on and do the trailer too.
The other problem with the JDJ was the suspension wearing out. I do a lot of small excavation jobs in the summer months and haul a lot of heavy loads to and from my job sites. This really isn't a JDJ problem but any trailer that has springs and shackles for suspension is going to wear out. In my case, it became an annual spring event to replace bolts, shackles and sometimes even do some welding on suspension components to replace worn out items. It was a few hundred dollars more to upgrade to the TorFlex axles on my Moritz and in two years I have not had to touch the suspension.
I looked at the photos of the Hawke and I notice that the cord and controller for their dump trailer appear to be in a little open holder on the front of the trailer. This is definitely not something I would want in our climate with the salt spray in the winter time. I prefer a larger front toolbox that contains the battery, dump hydraulics and controls that keeps them out of the weather.
The only problem I have had with the 7'x14' is making sure I don't overload it and do not put too much heavy material in the front as that makes it harder to dump. I once had to remove a couple of buckets of material from the front when I overloaded mine but now I count the number of buckets I put in to ensure I do not exceed capacity. My B26 fits in the 7'x14' nicely but I still have the hoe hanging over the tongue and the back doors won't close tight but I just bungee them together.
   / Dump trailers
I'm in north east Massachusetts. Closest dealer looks to be in NY
   / Dump trailers #13
I have a 2002 6x10 10,000 lb deckover BriMar. No problems dumping with a good battery. I purchased it in early 2009 from the original owner, they had replaced the deck sheet metal shortly before I purchased it. The original owner was a remodeling contractor and it probably sat with stuff in it on job sites etc.
   / Dump trailers #14
I have a PJ 14 ft X83 inches, Goose neck, I had a problem with poor welds in the D ring at the base of the cylinder, It was rebuilt and PJ paid the full bill.
I would buy anouther if I ever needed one, I have hauled a lot of rock with it, I did weld the center seam for the deck plates, I can haul 3 cords of cut fire wood with 1 ft sides. I just replaced the battery, after 4 years.
I use it to haul my loader, and custom orders now, mostly, besides getting wood.
   / Dump trailers #15
One thing I forgot to mention is that I line the inside of my dumpers with 2x6 and 2x8 pressure treated lumber. It adds a little bit of weight but it protects the steel from getting all dented. I have found that once the steel sides and bottom start to get dented the paint cracks and start to rust faster. I grease the trailer decking prior to installing the wood to at least slow down rusting that may occur under the wood.
   / Dump trailers #16
I'm another brimar owner 6' x 10' deck over, 10,000lb capacity Tows excellent. Love the trailer. One of the best purchases I have made. I have hauled tons and tons with it.
There is a dealer in Franklin CT Khan Tractor.
   / Dump trailers #17
I spent the day at a fully stocked and very knowledgeable PJ trailer Dealer in Rice Lake today...Pete Trailer Sales. Mark went over the trailers with us. All of the dump trailers we looked at were powdercoated. I was quite impressed and we will be picking one up this spring. We replaced our 24 ft gooseneck with a 32 ft PJ today with the hydaulic dovetail today. Picture is of Mark the salesman with Angela my wife.
   / Dump trailers #18
What Picture?
:confused:Matt
   / Dump trailers #19
here is the picture
   / Dump trailers #20
We had real bad luck with a Cam 7x12 dump in our construction business. It's 5-6 years old now, half the paint is gone, all the tires have gone bad, sides and bed mostly rotted out, jack worn out, batteries, etc. The barn door hinges failed, safety chains hooks failed.
These trailers don't lead a pretty life, I know. It helps not to leave them around with stuff in them, but that's what construction requires. We always line the floor with poly in freezing weather to avoid chipping out the debris.
I heard Cam was bought out, and the newer ones have better paint, but I'd not repeat an earlier pain like this.
Jim, wary
iDrive TDS-2010H...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Bobcat MT85 (A60462)
CATERPILLAR 299D3 SKID STEER (A60429)
CATERPILLAR 299D3...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
