Proper storage for sprayer pump?
   / Proper storage for sprayer pump? #1
lhfarm
Central Indiana
NH TC40DA
I had to purchase a new roller pump for my boom sprayer. Hadn't used the sprayer in a few years and the pump was frozen. The new pump's instructions say to fill the pump with antifreeze and plug. That is what I did with the old pump and it didn't seem to work well. What do you use for long term storage of these pumps?
Thanks!
   / Proper storage for sprayer pump? #2
Normal practice is to fill them with clean oil around here.
   / Proper storage for sprayer pump? #3
I fill mine with anti-freeze. I've got a loop of hose between in and out. Been doing it that way for 3 years, no problems. Curious why you had to buy a new one, couldn't it be rebuilt? Mark
   / Proper storage for sprayer pump? #4
I fill mine with burned motor oil.
   / Proper storage for sprayer pump? #5
I put a few oz of gear or hydro oil in mine. Going on five years old, still going strong.
   / Proper storage for sprayer pump? #6
Why burnt motor oil, when some of these pumps cost $150-500 ? They don't hold very much oil.
   / Proper storage for sprayer pump? #7
Why not? Its not going to rust with either new or old oil.
I used the sprayer filled with water for my prairie grass burn. I had waited until the last minute to mount the sprayer and the pump wouldn't turn and I couldn't break it loose. So I went to town and picked up a new pump.
Don't know if I could rebuild the old one, but no more than I use the sprayer I may send it to recycling.
   / Proper storage for sprayer pump? #9
Do whatever pleases you. When I have probably 10-15 quarts new oil left over from vehicles that I no longer own and the ones we own now don't use that particular weight I'm not about put black nasty oil in a pump we just paid $300 for. How much can you possibly get in the pump 2 to 4 oz.? Our oil change drain pans contain all kinds of sediment crap on the bottom that gets stirred up when we change oil that I wouldn't put on anything more than a sickle bar cutter.
   / Proper storage for sprayer pump? #10
My old oil is stored in drums. Allowed to settle for months if not years. Then run thru a 100 mesh strainer followed by a water separator then a 10 micron filter. My pumps have not spontaneously combusted or killed any baby seals yet using this method.
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
