5 or 6' Box Blade Scraper for Cub Cadet 7305?
   / 5 or 6' Box Blade Scraper for Cub Cadet 7305? #1
deezler
Elite Member
Southeast MI
Cub Cadet 7305, Kioti CK3510seh TLB
Hi everyone, thanks in advance for any helpful insight here.
I really want (need) a box blade for my new tractor. I am trying to break ground on my new property - repair the scraggly little bit of actual "driveway" and add in a long new extension, and make smoother trails over my generally lumpy terrain.
I was feeling pretty set on a 5' box blade (tractor width with the R4s is ~58"), but money is super tight right now. And all I see used on local craigslist's are 6' models. Have been watching them daily waiting for a 5' box to pop up.... but it never does. So the question is, could my tractor handle a 6 footer? Or would I just be cursing myself as it hangs up on roots and rocks and stalls the tractor repeatedly. I am generally of the opinion to get the right sized equipment such that you can maintain power and speed when working. But if a 6' box blade added a significant amount of additional weight, would that help it be more effective too? Note: I have several areas of sloping terrain to work with, too.
Tractor specs:
Cub Cadet 7305 (Mitsubishi built, generally pretty stout) Low hours.
30 HP, 4WD, differential lock, 3-range hydro trans
Weight: ~2700 lbs, + loader. Tires NOT loaded.
Need to smooth out terrain like this as I punch into the woods:
Here is my little scraggly bit of driveway up by my road frontage. I want to rip it up to smooth it out, pack it back down, then add 4-6" of new clean rock on top.
   / 5 or 6' Box Blade Scraper for Cub Cadet 7305? #2
A 6-footer you can buy is better than a 5-footer you can't buy.
Even if you have to take it easy during your reconstruction, it should be just about right for later maintenance.
Bruce
Haha, yes, a 6' box blade would probably be more effective than a non-existent 5 footer.
I suppose I should have added that the other consideration is to buy a NEW 5' box blade. We are really only talking about a couple hundred dollars more for a new 5' United blade from everything attachments vs. most of the used stuff I am seeing around here.
But my main question is how much less capable, or how much slower am I going to have to work, to get stuff done with a 6' vs 5' blade......?
   / 5 or 6' Box Blade Scraper for Cub Cadet 7305? #4
Specs on 7305: Wheelbase-67 inches, engine gross HP-30, net HP-27, PTO HP-24, 1653 pounds rear lift at 24 inches. Depending on the type of soil, I would think the 6 footer would suit your needs.
   / 5 or 6' Box Blade Scraper for Cub Cadet 7305? #5
Deez -
I'm in the same boat, searching for the right size BB . :confused2: In your case, I would venture to say either would be OK. Keep in mind, every box blade has a different weight. Some are 300....some are 1000. Find the right weight, and you should be OK!!!
Yeah I am not worried about the tractor lifting or carrying a 72" blade, just it having enough tractive force to pull it with ease. Depending on soil... hmmm... I have: Sandy loam, silty mud, clay and rubble in-fill, tired old gravel driveway base, and root-filled brush zones.
Well, what is the "right" weight? I am thinking the heavier the better. I'd be happy to see 5 to 600 pounds, but most 5 footers are more like 400 lbs.
I don't have the money for any of these (yet), but my top three choices are looking like:
1. Everything-Attachments-66-Inch-Box-Blade
2. King-Kutter-Professional-Tractor-Box-Blade
3. United-566HD-Heavy-Duty-Tractor-Box-Blade-66
All of these look better than the tractor-supply or northern tool type options to me.
   / 5 or 6' Box Blade Scraper for Cub Cadet 7305? #7
For the road work, the 6' would be good. For the rough stuff, you don't have enough tractor to "easily" drag even a 5 ft. Roots are tough tough tough and will stop you dead. heck, they will stop a tractor twice that size.
Buy the heaviest implement you can and that will typically be your best one. The worry I have is that if you get a root on an edge a light box will pretzel up. Just keep that in mind.
   / 5 or 6' Box Blade Scraper for Cub Cadet 7305? #9
6' is definitely better than none. What I would do as well is go around to local dealerships. The dealers are especially good, but a lot of times you'll find used implements for great prices that have sat on dealers lots for years.
^ yes ford tractor does make some good points. That's kind of the opinion I was seeking - that I should pass on 72" used box blades because I just don't have enough tractor to pull one through the rough stuff.
So, if I go with the conservative approach and find a new 5 foot box blade... it's kind of hard to tell what model would be better than another. The weight is typically pretty comparable, so I guess I am looking for:
- front AND rear cutting blades, ideally reversible.
- good bracing between the 3-pt mounting and the rear moldboard
- clevis style mounting on the lower arms vs the simple pin.
- more shanks are better than less (so, 5 is better than 4 in the case of a 5' BB)
Any thoughts on my selection criteria?
Good tip Martian. I might have to make some calls.
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
