Questions and problems with my DK55C, KB2485, and KL551
   / Questions and problems with my DK55C, KB2485, and KL551 #11
How would welding the bolt head be less effective? It is the bolts backing off, if there was a couple of tacs on the bolt head this would stop the bolt from backing off. The main problem. Welding the bracket on seems overkill, even if it was one plane.
   / Questions and problems with my DK55C, KB2485, and KL551 #12
Welding the parts together keeps them immobile. Tacking the bolt heads does nothing if the nut isn't also secured. Tacking the nut to the bolt would keep the bolt from loosening, but not stretching, which is a part of the problem. The mobility of the various parts is still not addressed. The original hardware simply cannot provide sufficient clamp load to immobilize the parts. Welding the pieces together is not overkill, but the best solution.
   / Questions and problems with my DK55C, KB2485, and KL551 #13
Too bad the OPs last activity on the forum was three years ago, would be interesting to hear if welding the parts transferred a stress load somewhere else that wasn't designed for it and failed.
   / Questions and problems with my DK55C, KB2485, and KL551 #14
I doubt it. The OP was neither the first nor the last to have these symptoms.
   / Questions and problems with my DK55C, KB2485, and KL551 #15
No. It doesn't cause any problems/stress loades elsewere.
I welded mine for the same reason years ago.
It solved the problem.
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
2019 GALYEAN...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
Ford 8510 (A53317)
Ford 8510 (A53317)
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56435)
2020 John Deere...
