Loader Hydraulic Quick Connects Persnickery
/ Hydraulic Quick Connects Persnickery #1
carpec53
UPSTATE NEW YORK
KUBOTA B3030
I just took the snowblower off my B3030 and tried to hook up the FEL. I couldn't get any of the hydraulic quick connects hooked up. The tractor is shut off and I moved the lever to release any pressure on it but the quick connects will only go on about 3/4 of the way and that is it. Not far enough to lock. Is there any trick to connecting these? Usually it is really easy but sometimes they just won't co-operate.
Thanks
/ Hydraulic Quick Connects Persnickery #2
Try using a blunt object, like a dowel, nail set or punch, to depress the ball. Don't hammer it, just push with it. If the ball won't depress then there is still a bit of pressure.
If the ball depresses but some fluid comes out it may have been just enough pressure to make hooking up difficult.
The other thing I have done is to hose down the area with WD40 to flush out any dirt or debris and also provide some lube.
Good luck.
/ Hydraulic Quick Connects Persnickery #3
The problem is caused by multiple things. When you start to take the loader off next time, be sure to really release all pressure by moving the loader control valve lever multiple times to all positions before you remove the connectors. This helps relieve residual pressure in the lines, and helps to "settle the loader" on the ground before removal. But it can still settle some after remove which re pressurizes the lines. Another problem is what is the temp when you removed the loader vs. when you try to attach it again. If it has warmed up and the loader lines sitting in sunshine will get warmer and re pressure the lines. About all you can do is get a piece of wood and a clean rag and attempt to force the check ball back and release the pressure (carefully as you will get a showerbath of oil) or get wrenches and "crack the fitting" by partially unscrewing the coupler fitting on the loader lines until it leaks out a little fluid thus relieving the pressure. I always used the wood and rag method, but learned to really settle the loader good first on the ground so there is absolutley not movement in the loader when moving the control lever. Also don't have your foot on the brake of the tractor so that its does not put any pressure on the loader either. You want that loader settled. But you still may have to deal with the take it off cold and put it back on hot thing. Sometimes you can just get mad and man up and "force" the darn thing back on through brute strength and ignorance also. Good luck with one of those methods.
James K0UA
/ Hydraulic Quick Connects Persnickery #4
I keep a short length of 3/8" wooden dowel under the seat, I often have to put it in the fitting and give it a whack to depress the ball and relieve the pressure buildup. Make sure you put a rag around it, stuff can spray out.
Thanks everybody! The short dowel idea worked great. I learned real quick to put a rag around the whole thing though to keep the oil from flying. I guess there was just enough pressure on the fittings to hold them apart. You saved some of my hair (and I don't have a lot to lose)! :thumbsup:
/ Hydraulic Quick Connects Persnickery #6
Or chill
I've had that happen several times with my backhoe, first time I waited till next morning, second time I hosed the lines down with water, last time, about a week ago I again waited till morning. I tried as hard as possible (250lbs of me) to press the ball against wood but it wouldn't leak a drip.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2022 EZ-GO ELITE...
2013 Hagie STS 12 Sprayer (A63111)
2013 Hagie STS 12...
Gehl RS5-19 (A62177)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
