Oil & Fuel BX25 stalling out
/ BX25 stalling out #1
Atv adventure tours
Barrie, Ontario Canada
Kubota BX25
Have a BX25 with about 340 hours on it. While I am running it for no apparent reason it stalls out. When I put the key to accessory I could not hear the fuel pump priming so I thought it was the pump. I put a new one on thinking I fixed my problem but is still doing it, runs for a few hours and stalls out. I have checked my transmission fluid and it's ok. Any ideas what it could be?
/ BX25 stalling out #2
/ BX25 stalling out #3
Believe the vent on the tank is in the tank cap, could be plugged, causing the tank not to let the fuel flow properly.
/ BX25 stalling out #4
I'd bet the 1st fuel filter is the problem. Just a small amount of water will stop the flow of fuel. Change it and you will be fine.
/ BX25 stalling out #6
I disagree with others here about filters. Your tractor is too new to have that problem if you only use fuel from the stations all the time. You mentioned you can't hear the pump so I am thinking more of along the lines of safety switches.
HST pedal and pto engage switch comes to mind. I wonder if the seat switch is causing it since its stalling out as you have 2 switches.
I would run down the checklist of switches and wiring harness to make sure nothing is pinched (unlikely wiring but free to check).
OTOH, I'd check and replace the first filter under BX since its so easy and simple to check and replace, but I really think its switches.
/ BX25 stalling out #7
Sorry radioman, I had the same problem, pulled the outlet line off the first filter, plugged solid, no flow, changed filter, problem solved. This was at 380 hours, always filled from clean cans and now a filtered pump from bulk tank. Cut plugged filter open, full of flaky black stuff like paint flakes. Probably from factory aseembly. Found the same stuff in nthe hydraulic strainer and filter at 50 hr.
Ron
/ BX25 stalling out #8
no worries seabee, I have been known to be wrong at times, but I was reading into the fact OP says he can't hear pump when its turned on. It could very well be the fact its plugged up in line and pump is off since the pressure is already high so it may not need to run :confused3: .
Thats what we are here for as brainstorming tank.;) OP - any luck so far?
/ BX25 stalling out
Thanks guys for the tips. I found the problem, you would never guess what it was. While checking the wiring going to the fuel pump I noticed a bad ground. It turned out while out in the bush with the tractor I caught a branch and it snagged a wiring harness under the tractor damaging the ground wire to the point only the insulation was holding the wire together. Sometimes the wire would make contact and sometimes it wouldn't making the tractor stall out. Who would have thought :) So now it's fixed and working fine again. But, I'm out with it yesterday and I got a cut in the side wall of my front tire :( what's next.
/ BX25 stalling out #12
May want to invest in some skid plates. Watch the HST fan blades if brush can stretch wires to breakage at that height.
/ BX25 stalling out #13
I am glad you found the fix. I would not have guessed a poor ground issue, although its not uncommon on any equipment regardless of color. At least I knew it couldn't be filters. :eek:
/ BX25 stalling out #14
Hello, I found this thread and it appears that my kubota BX25 is doing the same thing. It will start and sound normal and then all of a sudden start to stall out and then stall out. Is there a list of things I should check in an order I should check. My tractor was bought in 2011 and only has 150 hours on it. It is kept outside for the most part. Any advice would be greatly appreciated. Thanks in advance for the help.
/ BX25 stalling out #15
Go over all the ideas above, it could be any one of them, nothing was covered i can think of. I have that once in awhile and it is always the first fuel filter. I swear a pint of black enamel was spilled in the fuel tank at the factory. I get that black gunk also.
Ron
/ BX25 stalling out #16
Anyone have some new ideas please?
I've been struggling with a similar issue for 2 years.
Have changed both filters 4 times. Pumped all fuel out of the tank from the outlet through a filter 2 times. Installed a 100 dollar Racor filter. It stalled the very next time.
I have a 2 acre lot with a belly finish mower. I mow the front with never a problem. When I go to the back it will first drop RPM, then start running rough, then will stall. If I stop the mower deck, it may not totally die but if I try to move the mower it will again run poorly and die unless I stop moving. The back is very thick and hard to mow. The front is not. Also the back has inclines front not. I am starting to wonder about overheating. The fuel gauge doesn't work and I wonder if the temp is also giving me false readings. It stay in the middle when working. But last time I turn off the motor and on a few times and the temp needle edge up a little further each time.
Please give me a new idea!!!
/ BX25 stalling out #17
ATV Tours, I agree with GaryBake. GET SOME UNDER ARMOR ! ! If you hung the wires on the underside of your tractor with brush and such you really need to check the HST fan and make sure all the blades are still on it. I've got a BX22 and the HST fan is easy to change but on your tractor its a major ordeal.
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
