cutting mower blades
/ cutting mower blades #1
Kitz
anywhere usa
IH 244
Would anybody know what will cut thru a tempered mower blade. Ive got some real nice blades that the center hole is to smal. Ive went thru 2 bits so far. Thanks :confused:
/ cutting mower blades #2
Do you have a dremel that you can grind a hole, or a step-bit just go slow and cutting fluid.
is 500 rpm slow enough thats as low as my drill press will go. i guess grinding a hole is the other option i used a couple bits and burn them up. im trying to get 7/8"
thx
/ cutting mower blades #4
Carbide would probably cut through but carbide is brittle and you must have the work piece clamped rigid. 7/8 carbide drill would probably cost more than the blades also.
/ cutting mower blades #5
I performed a similar job not to long ago, used a die grinder and just kept at it, wore the stone down pretty good but did what I wanted.
/ cutting mower blades #6
I think some of the guys in the welding forum were saying 250rpm for steel.
/ cutting mower blades #7
Took it to a machine shop, put in mill and used a 7/8 carbide bit. Slow and lots of fluid, drilled 3 of them.
/ cutting mower blades #8
Makes me wonder the quality of the drill bits you are using.
There are a lot of Chinese drill bits being sold that are good for
wood or plastic only not for steel. I can't think a good quality bit would
not go right through a lawnmower blade. They are not that hard, if they
were, they would shatter on the first rock. Think how easy they are
to sharpen with a file.
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
