Quick disconnects for remotes
/ Quick disconnects for remotes #1
Yoteroller
Mountain Home, Idaho
Mahindra mPower 85
Anyone know the correct male end for the hydraulic remotes on a 7060? Anyhelp is greatly appreciated. Thanks
Dave
/ Quick disconnects for remotes #2
Dave
About any std 1/2" ball or poppet end will work. 1/2" AG type quick connects are what is std on most all of the tractors 100hp and less. ;)
Thanks Brian. I hooked up a piece of machinery yesterday and the remotes leaked like a sieve. The male ends are 1/2" ball type and looking in the remote on the tractor I see they're different -- having a point rather than a ball. I guess that's the "poppet" type? I'll try the poppet style and see if that takes care of it. Thanks again
Dave
/ Quick disconnects for remotes #4
I hope that it takes care of it. Are there any o'rings in the tractor ends? The poppet and the ball type should be able to work with each other without having any problems. I know that I use both types with my Mahindra 7520.
/ Quick disconnects for remotes #5
Dave
I have Pioneer poppet style quick disconnects on my Mahindra 5525 (triple rear remotes, dealer installed). They work fine as long as something is connected. Other wise they leak (seepage). I rigged up a set of plugs to use when the remotes aren't in use to stop the leaks.
I picked up and installed a couple of the 1/2" poppet type male ends and they lock up tight, no leaks and work great. Thanks for the help.
KUBOTA BRUSHGUARD PART (A62130)
KUBOTA BRUSHGUARD...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
New Holland Workmaster 75 Tractor (A61166)
New Holland...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2012 Ford F-750...
UNUSED WOLVERINE QC7-26-12.5G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
