Easy, low buck, exhaust mod to eliminate soot on FEL
   / Easy, low buck, exhaust mod to eliminate soot on FEL
So I have probably 30-40hrs since the exhaust mod. I have to say that I have found only one down side. It does blow some dust at higher RPMS. But I only noticed when I was watching my brother-in-law drive it. :D I only wish that I had done it earlier and to my other tractors. :thumbsup:
   / Easy, low buck, exhaust mod to eliminate soot on FEL #22
Good to hear it is working well for you. I'm now trying to decide between this mod or doing a stack, have 17 hours on mine now and the fel arm is getting covered in soot.
   / Easy, low buck, exhaust mod to eliminate soot on FEL #23
Why not use a piece of high temp heater hose ??
Yup, that's a tuffy. I decided that I didn't want to go through that much work to do a stack for little or no gain. But that is my opinion.
Even though it's high temp, it will break down with the heat over time. Besides, they do have flexible exhaust, although I don't recommend it. Flex exhaust pipe has horrible flow characteristics, causing a lot of turbulence in the pipe. Then again probably not gonna be noticeable on our tractors though. :confused3:
   / Easy, low buck, exhaust mod to eliminate soot on FEL #25
Little or no gain! :confused2: Your kidding right. No dust or snow being kicked up with a stack. No soot.
The stack makes the tactor look like a "real" tractor. Then there's the cool factor and the fact not everyone will have it. Yes it's allot of work but the best route to go BUT that's just my opinion :laughing:
   / Easy, low buck, exhaust mod to eliminate soot on FEL #26
Thanks HC, nice work, the pic say it all..I missed 4 shorts...JY.
   / Easy, low buck, exhaust mod to eliminate soot on FEL #28
Your original photos, i should have looked back in forum, instead of commenting here?I like the idea of putting the exhaust down..
   / Easy, low buck, exhaust mod to eliminate soot on FEL #30
4 years on mine already,, When you think it will start breaking down ???
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
Cushman Cart (A55853)
6-Band Wooden Barrel (A55853)
6-Band Wooden...
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
UNUSED RAYTREE RABC44 - 44" BRUSH CUTTER (A57193)
UNUSED RAYTREE...
JCB 300T SKID STEER (A52707)
JCB 300T SKID...
