Dodge Intrepid - First car, what do you think?
   / Dodge Intrepid - First car, what do you think? #61
The LH are notorious for holes in the AC and or radiator bottom because they hang down low & act as a bulldozer in snow or gravel berms...
Anyways pages of comments & NOBODY has asked the most important question...
How does the radio sound???
   / Dodge Intrepid - First car, what do you think? #62
The air dam hangs low on the intrepids. Parking curbs are notorious for pulling them loose. I'd reattach it with some new pins and stock some spare pins. Watch what you drive over..........it's not a 4 x 4. :D :thumbsup: A mechanic once told me not to remove the air dam. It has a purpose but I don't remember exactly what it is now........
Don
   / Dodge Intrepid - First car, what do you think? #63
Don
Typically the purpose is to funnel more air up to the radiator, since the design of alot of newer cars dont really have a grill to let air flow straight through.
But I have removed the air dam when it came loose on more than one car and never had an overheating issue as a result
   / Dodge Intrepid - First car, what do you think? #64
On the other hand you will gain alot of mechanical experience with this ownership. It would sure help your confidence level if it remained trouble / leak free for at least a week. Good Luck.
I just meant you got a good buy.
Chris
Yeah, I understand. You were making you post as I was making mine about the problems...
I wouldn't know...I get distracted by the radio, so I don't usually listen...Heck, sometimes I get distracted when the window is down...:D
Thanks for all the input so far.
I checked the trans fluid and it was low and brown, so it might need to be changed. The car is at the mechanic's right now to fix the problems previously mentioned. We are also getting the A/C repaired and the drivers window looked at. The previous owner had made us aware of these problems prior to the sale...
We will see...
   / Dodge Intrepid - First car, what do you think? #67
Make sure you use the required tranny fluid (I think it is outlined on the dipstick) - I had a 1997 with the 3.5 which was a great car (290K when sold) - but I do remember the tranny guy saying it takes "special" fluid - not your std stuff?
   / Dodge Intrepid - First car, what do you think? #68
Kyle:
Free advice can be useful, so here's some more. I hope it's worth more than what you are paying for it. When my son got his first car, I helped him find a good little pickup as he would be able to carry around his dirt bike and trucks are a little easier for us to fix. It didn't hurt that he couldn't carry too many passengers. The unexpected bonus is that he was able to use it to make some money. LOTS of people need small amounts of junk hauled away, yards cleaned up and grass cut. In six months he saved enough to buy a five year old Z28 Camaro and then complained That I wouldn't let him borrow my truck. Just food for thought.
UPDATE:
Took the car into the shop...Cost $500...
They attached the air dam, serviced the A/C system (including refrigerant & dye), repaired the drivers power window (the big $$$), added fluid to the tranny, and diagnosed the leak. It turns out the leak is in a tranny cooler line, but it would be a $800+ job. So for now we will just keep an eye on it and add fluid as needed...
   / Dodge Intrepid - First car, what do you think? #70
Glad you were able to get it fixed up for the most part. :thumbsup:
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Informational Lot - Financing (A51039)
Informational Lot...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
