Oil & Fuel Type of oil to use
   / Type of oil to use #1
Ford4600
Ford 4600
What type (weight) of engine oil to use its a diesel
Thanks
   / Type of oil to use #2
Best to look at owners manual. One machine may take 15w-40, while another may take 10w-30.
I don't have the owner manual and I can't find any info on the net
   / Type of oil to use #4
Thanks
API classification diesel oil (CJ orCI, what ever the latest is) SAE 15W40 works for most diesels in ambient temperatures above ~32F.
   / Type of oil to use #5
If you really want to be sure, spend as few extra pennies and get synthetic diesel rated oil, it generally covers a much wider operating range. I use Rotella T6 in everything I own. You can get it at your local Walmart for about $20 a gallon
   / Type of oil to use #6
Some CJ oils are not backwards compatible to the CI-4 spec and are intended for Tier IV compliant engines only.
   / Type of oil to use #7
Here is the latest list I have been able to find. Some of my older diesel tractors had more latitude in oil specs than the new ones that have
tighter tolerances and need oils with better/quicker lubrication.
  • 2009_ENGINE_OIL_GUIDE.pdf
   / Type of oil to use #8
The API data in the post below yousr says that CJ's are backward compatible if used with ULSD fuels.
   / Type of oil to use #9
New Holland recommends it's new CJ oil only be used in Tier IV engines.
The cost of many CJ oils make the backwards compatible question moot. I won't be buying any until I have an engine that requires it. And that won't be any time soon.
Thanks for all the answers
2001 MACK CX613 SLEEPER (A58018)
2001 MACK CX613...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
2018 New Holland C227 Compact Track Loader (A56435)
2018 New Holland...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
