CT335 - MLS Valve Issue
/ CT335 - MLS Valve Issue #1
robertwhite
OK, need some help here.
My CT335's MLS valve knob is stuck. I can not loosen it and I sure don't want to try and turn it any harder than I have as it will surely snap the shaft that goes into the case and then I have really big problems.
The 3pt goes up and down, I just have no control over how fast. If I push the lowering lever (?) (on right side) the 3pt will kind of jump down. I basically can not feather it.
Anyone know how I can fix it short of splitting the case?
/ CT335 - MLS Valve Issue #2
Drops quickly now would indicate it is full open to fast side so don't try to turn it to any faster, keep trying to turn towards the turtle. Spray some good penitrate right at shaft wear it goes into the MLS valve and let it soak and trying. PB Blaster is pretty good stuff, there are others out there too.
If you have to remove it the MLS valve unbolts and comes out as an assembly without having to take the complete Rock Shaft Housing off the top.
No, it does not drop fast. It only drops fast because once I "defeat" the pressure on the up/down lever, it drops to where the lever setting is at.
The KNOB between your feet is stuck in the position a closed outside faucet would be in. (I don't know if that is actually part of the MLS valve itself)
Where does it unbolt from?
/ CT335 - MLS Valve Issue #4
Seat will have to come off the see the MLS valve & where that adjusting rod connects to it. Follow that rod back and you will see where a pin goes through the linkage and into a round shaft. Spray that shaft with some loosening agent.
What I meant by dropping fast is when you lower the lever 3pt comes down fast or faster than you can control. That tells me the adjustment may to fully to the rabbit side. Trying to avoid damage work it towards the turtle (slower) setting after some lubricant has had time to soak.
/ CT335 - MLS Valve Issue #5
The one on my Kubota was stuck when delivered.. I used Kroil ( a penetrating oil) and let it sit for a bit, finally got a pair of water pump pliers and "wiggled" it back and forth a bit, CAREFULLY. It soon freed up and is easy to turn now. I final lubed with Fluid film to prevent any water going down the shaft, as fluid film stays put.
James K0UA
Thanks, that did the trick. :thumbsup:
John Deere S350 (A60462)
John Deere S350...
2022 EZ-GO ELITE...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
40' Shipping Container (A66285)
40' Shipping...
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
