mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,362
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
I'll re-post this from LogDog's thread as my "entry":
"There are 28 - 6x6x8' Cedar logs in this bundle. They weigh between 85 and 105 lbs each. Since they were cut green and stored outside I would lean more towards 100lb ea. It didn't like it, but it lifted and curled it. I regularly lift around 2K with no problems and traded in a CK30 for the DK mostly for the extra loader capacity...it has not disappointed me in over 600 hrs.."
That's the most it's ever lifted, but not the most I ever attempted....dang relief valve stops me from being too schtoopid:laughing:
For size of the machine, I think you are the winner! Are you sure you did not cheat a bit on the relief valve. I did, just only 5%.
I have a L39 Kubota, and I suspect we are about tied in lift ability, maybe the L39 has the edge in lift, but you may have me on curl, as curl is not the L39 strong point. Hard to tell as The L39 is rated center 500 MM from pins including HD bucket weight and Koiti's are rated at pins.
What do you have for a counterweight? Besides the 1,800 lb. BH I added another 850 Lbs of steel to wheels and frame to reduce pucker factor.
I believe the Kioti 4XX loaders are the stongest for their size of any Ag type tractor. The LA-85X series on the biggest grand L Kubota's may come close, but I think you would need the Kubota M seires loader to be stronger.
