3-Point Hitch ck25, 27 and 30 owners - please help with measurement
   / ck25, 27 and 30 owners - please help with measurement #1
dkizerian
Erda, Utah
Kubota B7300
Hi,
I'm trying to replace a bent adjustable lift arm off of my kubota, and really like the crank style on the Kioti's I've seen.
I need the arm to have yokes on both ends, which I think rules out the ck20.
Can I get owners of a ck25, ck27 and ck30 to measure the length of this arm at it's shortest and longest lengths (hole-center to hole-center), and also internal width of the top and bottom yokes.
I've included a picture of the part I'm asking about.
Thank You
Dave K
   / ck25, 27 and 30 owners - please help with measurement #2
Hi,
Thank You
Dave K
I'll be going out tonight to clean up the snow we've been getting, I'll try to remember to take a tape measure with me.
   / ck25, 27 and 30 owners - please help with measurement #3
I have my tiller mounted so did not measure full travel of the adjustment but if the stationary (left side) measures the same as yours the right side shoudl work. Stationary link is:
Top clevis width ID - 1&3/16"
Bottom clevis ID- 3/4"
From top to bottom pin center - 16" first hole & 17" to lower hole
Uses 3/4" pin dia.
SSdoxie, thank you for measuring this! I've lost my notes on my piece of course, so I'm going to remeasure mine in the next couple of days. I think the yokes are good, but the length might be a little long.
Length is good, and bottom yoke is good, top is only 7/8" on the kubota but washers would work for that...
Unfortunately the pins on my tractor are only 1/2"... drilling the bottom out for a bigger pin would be no problem, but the top doesn't seem like it will work, since it's a ball on mine..
Thanks again for the measurements though!
   / ck25, 27 and 30 owners - please help with measurement #6
Mine measurements are also the same, and I got a ball on top to.
   / ck25, 27 and 30 owners - please help with measurement #7
Could you use 1/2" pins and make bushings to go in the lift link?
2015 Freightliner M2 Chipper bucket Truck (A52377)
2015 Freightliner...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2016 Jeep Wrangler Unlimited SUV (A55853)
2016 Jeep Wrangler...
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A57024)
2012 New Holland...
MINI EXCAVATOR BUCKET 32 (A55745)
MINI EXCAVATOR...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
