McCormick CT41 HST
/ McCormick CT41 HST #21
I have a 4041 EZ shift. I have no complaints so far but only have about 55 hours on it. As far as the loader, I have not had any trouble with the curl. I have only used it to spread gravel, fill and load horse poo. As previously stated, my loader has the bigger cylinders. I have added a TnT kit, ROPS lighting, and an air filter monitor. Toolbox is next.
No bad news from anyone, I might just have to buy this tractor.
Thank you for the feedback.
I have a 2010 R4010 gear 41HP (sold new to me last May). That model became the R4041 in 2011. My only beef is with the bucket roll-back power. They went to larger bucket cylinders and moved the joystick to the fender in 2011. I have about 260 hours on mine.
On edit: From every picture I can find, the McCormick is the same tractor with a different loader. The loader on the McCormick has different mounts as well. From what I can see, it would have better bucket leverage than my LS loader.
The McCormick has found it's way to the house for a trial run. I'd have to agree with you, I think the bucket might be over sized for the cylinders on the loader, It's very weak in the curl, Holds more than my L2800 does, just takes a little longer to get it in there.
Where do people put tool boxes on these things?
Casey
/ McCormick CT41 HST #24
I catch heck from the safety police because I keep my ROPS bar folded. I made a shelf there for my tool box, a chain box, and my winch battery. My saw scabbard is bolted to the ROPS bar too. I still plan to make my own bar top so I have that back. But, it has to be lower than the original by a bit to get under things I have to regularly get under.
On edit, the spell checker can't save you when the misspelled words are the wrong words.
Hey, you're being safe, I can see your ear protection in the photo. :)
The local safety police would have a problem with that here too. I do think a bar installed between the uprights is about the only spot though. I'll probably do something similar.
/ McCormick CT41 HST #26
Here's the flip-side.
The plan is to make shorter uprights that will pin into the old pin holes of the ROPS bar and put a bar across and build a sunshade on that. I want to make sweeps that come up from the loader mount to join the ROPS and support the roof. I need the lid to be about 7 inches lower than the stock ROPS.
/ McCormick CT41 HST #27
Holy cr@p, Batman! That's lots of stuff. I assume one of those has your lunch? :licking:
My ROPS was way too tall - I cut it down about 3 - 4 inches and it was much better.
Well I took the plunge & traded my Kubota for the McCormick. :) Went out the very next day & got a 3ph backhoe for it. :D Now if it will just stop raining I can get the drainage in that we need for all this rain :)
Thank you to everyone who helped me learn about this tractor.
Casey
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2005 John Deere 310SG Backhoe (A64047)
2005 John Deere...
International 9200 (A63118)
International 9200...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
