Feasable?
/ Feasable? #1
MrPete
Newport ME
Kubota BX 2660 Kubota MX 5100
Gentlemen, I need a question answered. I have a Murray lawn tractor with hydraustatic drive, with a 17 hp motor in it. The actual mower itself is shot but the motor and drive still works great. My question would the hydraulics of the hydr. drive help me in building a woodsplitter. I need a woodsplitter and I love to build things but I have never played with hydraulics:confused:. I know I need an I beam and a ram etc. but is the pump, tank and that heavy enough for a splitter. I also plan on using it's motor too. I tried searching but found nothing. Thanks for your help in advance.
/ Feasable? #2
No, different hydraulics. You be better off selling the MTD parts.
/ Feasable?
:(Thanks for the reply teg. Guess I'll go a different route.
/ Feasable? #4
Didn't have time before to get into it before. I tried to fix a lawn mower's hydrostatic transmission before and took some photos of it.
http://www.tractorbynet.com/forums/general-lawn-garden/97875-transmission-problem-scotts.html
I have parts from a "project" wood splitter... still a work in progress. The problem with building it yourself is the cost of hydraulics, your not going to save that much. I bought a used one and still fixing it up. Make sure you get it cheap because I got over $500 and still counting. Good luck with the project...
/ Feasable?
Wow, thanks teg! No I do not want toget into hst. And for the splitter info, I think your right. Without most of the hydraulics, it's really not worth pursueing!;)
/ Feasable? #6
I'll just add a second witness to Teg's advice. HST is not going to help you with a log splitter. You can get a lot of good hydraulic parts cheap, but you have to look for them.
About all you could use from your Murray for the logsplitter is the engine.
/ Feasable?
Thanks Iplayfarmer, after teg's remarks I have removed that idea from my little pea brain.
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
iDrive TDS-2010H...
APPROX (75) 2" X 2" X 8" ANGLE IRON (A64280)
APPROX (75) 2" X...
