If you're not supposed to use a FEL as a bulldozer, does that mean that I can't use it to scrape 8 inches of mud out of the horse paddock, or muck out the pig pen?
Serious question. I'm planning the purchase of a tractor, and that's one of the jobs that I need to accomplish.
Maybe a Deere 310 backhoe is a better choice?
Thanks
Not sure if a JD 310 would be a better choice for you are not?
I accidently wound up with an old worn out (starts and runs fine but every pin has double slop in it
 ) 1983 JD 310 B a couple years ago when looking for a FEL for the 1976 265 MF that was owned by the FIL and still has under 1300 hours on it.
The 310 B cost me $1200 ($7200 and may have over paid) more than the only real option I could find for a 60 HP tractor. For my use I did NOT want a FEL even without the bucket installed when bushhogging or using the box blade.
The 310 BH takes 40 acres to turn it around compared to the naked 265 MF but at 7.5 ton it will push over a lot of tall trees in 1st gear at 950 RPM. While the ground is still kind of soft the hoe will flip out 3"-6" trees with little effort.
If you have to go though a 6' gate to dig a sewer line in a 15'x20' back yard FORGET it. :laughing: CUT's can NOT be replaced in some cases with a heavy duty BH.
For farm/open land use I would not want less than the brute force of our our old 310. For a two wheel drive it gets around on soft gound (not knee deep mud) much better than I expected.
Using even an old very heavy duty backhoe like the JD 310 clearing ground is hard on them so be willing to replace some lines and such. Ours cab is not enclosed but seems strong enough to keep a heavy tree from crushing it. The key is to becareful and not let the cage make you feel like you are driving a tank.:thumbsup:
One plus of a true Backhoe model is you do not have to be concerned with sub frame issues because they are designed 10x stronger (my guess) than a typical CUT or farm tractor. When you have a BH down on the ground stuck and have the hoe tied to a tree and pushing backwards with FEL bucket curling there is some real stresses involve.
They are not cheap but the JD 110 would be smallest that I would buy for my use.
I have a hill I want to move up to the house to make a fill to build a shop some day. That should be about 200 loads of dirt on our 16' flat dump 1989 F700. Having a BH that can dig and with a 7.5' FEL will help speed up that job that we may take a year to complete because I plan to get the kids involved since it can be done without getting on any public roads in dry weather.
IF one is reading this thread out of true concern I would suggest getting a backhoe/FEL that is stonger than the tractor can tear up even with some abuse. If you have a 30 HP tractor get a FEL rated for a 40+ HP tractor if you can find on that will fit your bolt pattern.
Some one posted never to spin the back wheels when using a FEL. It is my guess they do not own a FEL or bought it to impress some lady.
