M9040 "Hissing" Noise
/ M9040 "Hissing" Noise #1
GregHammerstein
Georgia
Kubota M9040
I have a new M9040 4-wheel drive hydro-static transmission with less than 25 hours total time. The tractor produces an intermittent, but consistent "hissing" or "whistling" noise that is coming from the upper right-hand side of the engine compartment firewall. The noise comes and goes and seems to be related to and aggravated by increasing engine rpm slightly above idle. I've repeatedly been able to stop the noise by applying the brakes 3 to 4 times, either with both pedals together or either pedal separately. The noise goes away completely for about a minute but always returns. I can always clear the hissing noise by tapping the brakes several times. The noise definitely sounds like air hissing through a leaky hose. Curious if anyone has had similar experience or a recommendation before I go through the trouble of hauling this tractor back to the dealer. Thanks.
/ M9040 "Hissing" Noise #2
Sounds to me like regular turbo charger related noises. Not sure what the brakes have to do with it though. I wouldn't worry about it.
/ M9040 "Hissing" Noise #3
Have you asked your dealer about the noise??????
Thanks for the reply guys. I have asked my dealer about it and I'm waiting on a response from him. Although the tractor only has about 25 hours on it, the noise just started recently and was not present during the first 20 hours or so. Additionally, I drove two other brand new M9040 units at the dealership and neither one of those two made this very distinct noise.
/ M9040 "Hissing" Noise #5
When I bought my 8540 back in 2009, mine was making the same kind of noise you describe except it was coming from the right hand fender under the hydraulic levers. After trying to find out what it was, turned out to be the hydraulic valve for the remotes. Playing wiht the levers, I was able to make the noise stop, but it would come right back soon as I let them "rest" in their natural position. Guess something was out of adjustment or there was something preventing the valve from closing completely.
Called the dealer and he said go ahead and put some hours on it and if it didn't go away, they would find out what was going on. After doing the 50 hour service, it seemed to make it go away. Not sure this is your issue being that it's coming from under the hood, but might be worth ruling out it.
/ M9040 "Hissing" Noise #6
Both my present Kubota's 'hiss' but it's coming from the transmission case in the rear. It's the back pump circulating fluid..... normal sound
If you have an under the hood 'hiss', I'd take a quick look at the pressurized side of the turbocharger, the rubber hose from the turbo to the intercooler and from the intercooler to the intake. Loose clamps will cause a hissing sound when the turbo pressurizes the piping. No biggie.
Thanks for the replies guys. I previously checked the hydraulic valves to see if operating them had any effect on the noise but they do not. My M9040 has three additional optional valves as well and I checked them also. I will definitely check the turbo-charger lines but it's for certain that pumping the brakes stops the hissing (at least for a minute or two). Appreciate everyone's help very much.
/ M9040 "Hissing" Noise #8
I'm not familiar with the kubota M9040 with hydrostatic transmission, is this something new? I know that Kubota offers the M9540 with a hydraulic shuttle transmission, is that perhaps what you have?
My bad. I have several tractors and I'm bad about mixing up terminology. You are correct. The M9540 has a hydraulic shuttle transmission. And yes it's the 9540. I'm bad about typos with my iPad key-board. Sorry for any confusion.
/ M9040 "Hissing" Noise #10
The last company that offered a domestic hydro in an ag tractor was IH and that was years ago. We knew your didn't, or at least I did and probably a few others too.....
/ M9040 "Hissing" Noise #11
Does it hiss when NOT under a load or only when loaded? The turbo won't be building pressure without a load on the engine. "Assuming" you are operating the machine, hear a hiss, tap the brakes a few times (probably with the clutch in?) and the engine unloads, pressure goes down and the hiss stops. That would make me suspicious of a loose line between the turbo and intake manifold.
Other thing could be the "pop off valve" that keeps the turbo from over pressuring the engine. It shouldn't be bleeding pressure very frequently. If it's the cause, you may need to have the dealer adjust or replace it.
There's more, but those are the ones that come to mind. Maybe that will give you a direction to look.
/ M9040 "Hissing" Noise #12
You mean the 'waste gate'. You don't hear that anyway. All it is, is a sealed diaphram that senses boost pressure and actuates a butterfly vane in the turbo housing, limiting boost pressure...... It does have a hose attached but just a tiny one..... I doubt you'd hear it over engine noise.....
Thanks for the suggestion. Hissing noise is present loaded and unloaded. Clutch depressed or released. Operating the clutch does not have any affect. Operating the hydraulic valves does not have any affect. So far the only thing I've been able to consistently reproduce to eliminate the hissing sound is operating either one or both of the brake pedals. One or two depressions doesn't usually clear the noise. Three or four times or more is always effective. One single depression with continuous application also will NOT clear the noise.
Quick update. My dealer spoke with the local tech rep. They all agree it's likely being caused by debris in the pressure side of the brake valve in the pressure port fitting which houses the filter. The service manager was able to come by my place over the weekend and listen to the noise himself. He also agrees it's coming from the brake valve. Plan is to pull and replace the filter and check for debris in the port. The tech rep says there is an orifice in this port as well and if the debris is on the non-filter side of the orifice the valve will need to be replaced. This is dejavu for me because my M7040 made an unusual vibrating noise brand new off the lot and it turned out to be a metal shaving inside the hydraulic 3-way valve. Kubota knew exactly what this was when we described the noise to them and we went right to the valve and found the metal shaving inside. Will provide an update once we get inside the valve.
/ M9040 "Hissing" Noise #15
Interesting. Both my large frame Kubota's 'hiss' or should I say make a sloshing sound. Both are way out of warranty however.
What model Kubota tractors do you have and what years are they?
/ M9040 "Hissing" Noise #17
Lets see, a 105 S (which is 16x16 hydraulic shuttle) and it's 6 years old and a M9000 HDCC3 (12x12 hydraulic shuttle, 2 speed PTO) and it's 7 years old. I really have no issues with either other than the sound. I've changed the fluid and filters more than once (expensive change by the way at almost 15 gallons in the gearcase on each and fluid costing around 150 bucks a pail (5 gallons)). The 105 has around 400 hours on it and the 9 is over 1000.
I run Chevron full synthetic fluid in both. It's Kubota specification but it's orange colored.
/ M9040 "Hissing" Noise #18
Did you ever get this resolved? I have the same problem with a 7060.
/ M9040 "Hissing" Noise #19
I think you might be a little late - this thread is over six year old. Just saying.............
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
48ft. 38 Ton T/A Flatbed Trailer (A61568)
48ft. 38 Ton T/A...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A62131)
UNUSED WOLVERINE...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2019 East...
2021 Hamm Compactor HD 70i VV Asphalt Roller (A61166)
2021 Hamm...
