Backhoe 485 Capability
/ 485 Capability #1
Honey Dealer
Member
Saskatchewan
Would I be crazy to attempt to dig a basement for a 1400 sq foot house with a 485 mounted on a JD 4520?
I like the idea of the backhoe more or less paying for itself and then having it for small trenching and digging projects in the future.
/ 485 Capability #2
More or less, yes... I would suggest getting an older JD 310 or Case 580 preferably with an extend-a-hoe. For the same amount as the 485, you can have a machine that will far out dig, but be much older. I wouldn't dare try and dig a basement with a 485, though.
/ 485 Capability #3
I won't say it couldn't be done... but, I wouldn't recommend it. Eight foot basement with a 2 foot wide footer?
You'd have to dig with the tractor down in the hole to get the hole deep enough. So, one side of the hole would have to be sloped to allow the tractor to go down and back out with the excavated dirt. Back and forth, back and forth. 'Course the last side would pose a problem as the backhoe would only be able to dig down 8' or so.
If you're set on doing it yourself - I rent an excavator. You'd save time and money over buying the 485 and wouldn't have an older backhoe to maintain and/or resell, either.
AKfish
/ 485 Capability
Ok, forget about the basement. Surely the 485 has the capability to trench for geothermal?
/ 485 Capability #5
I don't think that a 485 has the diging depth to do geothermal...... I just did my geothermal this fall and it was 3 long weekends of hard work..... I even had a Cat 315 excavator and a good operater running it.......
If i where you I would rent a Cat 320 with a 48" bucket and get digging.;)
/ 485 Capability
Typical depth for geothermal is no more than 6 feet. It'd be a slow project, but I think it would work.
/ 485 Capability #7
I don't know where you live, but in SW Michigan you need to go atlest 10' down, and thats in clay which is grate soil for geothermal......
I had to did a 200' trench with a 485 in hard clay and it took about 1 day just to dig the trench. (BTW the trench was only 2' deep.)
I'm not trying to shy you away from the 485 its a good backhoe, its just that I think there are faster and more cheeper ways to do what you want to do out there....
/ 485 Capability #9
I am a long long ways North of you. Under the frost level and we are good to go.
Frost up here can go 9' on a bad winter! I'd be surprised if you run water lines less than 7' in SK. My horse waterer has frozen twice in the past 10 years. It's as deep as the 485 will absolutely dig - 8'6".
AKfish
/ 485 Capability #10
On this as many issues: time vs money. If you have the time, yep a 485 will dig the basement or geo trench. If you have the money, a real digging machine will do it faster, more accurate, and with a lot less work. I've done several largeish projects around here with the 448 Hoe on the 4520, and I can do an hour or so a night without impacting the paying job. If I rent I have to work straight through to make it pay.
You got more time or more money to spare?
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
Fuel Heater (A64047)
2009 KENWORTH T800 (INOPERABLE) (A63569)
2009 KENWORTH T800...
2012 MACK GRANITE-GU713 (INOPERABLE) (A63569)
2012 MACK...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Kubota RTV 500R-A Utility Vehicle (A64047)
Kubota RTV 500R-A...
