Hydraulic question on a Kubota M 6800
   / Hydraulic question on a Kubota M 6800 #11
I'm confused as to what the heck JJ's talking about also.
Seems like hes saying that if the 3point is still trying to lift load or trying to keep it in the up position,that your not also able to pump the needed fluid to the loader at same time. Does your 3point leak down when you park the tractor with load or will it hold it up,(say several hrs)?
   / Hydraulic question on a Kubota M 6800 #12
Of course it leaks down when off, they all do.
But when running, linkages connected to hydraulic valves lift the 3pt to the point where it matches your lever/handle. Once matched, it automatically goes to "neutral".
At least all the ones I played with.
Are Kubota's different ?
   / Hydraulic question on a Kubota M 6800 #13
What is it that you don't understand about the neutral position. Did you not read the data that I posted?
There are a lot of people that don't know that on some tractors, that with the 3pt lever in the raise position, that you may be causing the relief to activate, and that puts the 3pt relief pressure back through the hyd system.
Neutral position for the 3pt is where the lift arms are not going up or down. Maybe some of you call it something else, but that is what it is, neutral, meaning not doing any work.
Not moving up or down = neutral valve position
Put a hyd gage at the 3pt and see what the pressure is when the 3pt is in the fully raised position. Some 3pt valves will return to neutral automatically.
   / Hydraulic question on a Kubota M 6800 #14
Then their linkages are are out of adjustment and it would do the same without any load at all.
   / Hydraulic question on a Kubota M 6800 #16
In theory, with a perfect hyd 3pt system, it should hold up the attachment until you lower the unit.
Some 3pt levers will auto return to neutral, but they all have a neutral position.
   / Hydraulic question on a Kubota M 6800 #19
I can leave mine in shed all nite,with something on 3pt in the up position and it will still be up in the morning when I go back,or for days...............
Kubotas must be different!!!
   / Hydraulic question on a Kubota M 6800 #20
Not something that's selectable by the user.
Like I said, most all 3pts find there own neutral when it satisfies the lever location.
4ft Tarter Walk Through Gate/Panel (A48837)
4ft Tarter Walk...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A50459)
(INOP) JOHN DEERE...
DEWALT 8000 WATT GAS GENERATOR (A50460)
DEWALT 8000 WATT...
2001 Subaru Outback AWD SUV (A48082)
2001 Subaru...
2013 Fiat 500 Hatchback (A48082)
2013 Fiat 500...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
