Anyone running a late model JD 4720?
   / Anyone running a late model JD 4720? #11
Thanks for the feedback everyone. To follow up on some of your questions I will be doing a little square bailing for winter goat feed, maintaining an apple orchard, brush hogging, some grounding prepping for fruits/veggies, post hole digging, and maintaining about 2k feet of gravel drives. I have always been a power junking plus a power to weight ratio person. Getting into a new tractor of this value and size is a big leap for me so I want to do it right. I must say the welcome has been warn. :thumbsup: Thanks again.
I mow around 60 acres along with quite a bit of loader/grapple work very easily with a cabbed 4320.
Here are the list prices on open station units. I won't try and talk you out of the 4720 but for 15 acres I'd look hard at the others.
4720-$34,755.00
4520-$30,906.00
4320-$28,987.00
4120-$26,748.00
   / Anyone running a late model JD 4720? #12
BTW, when I first started looking, I was going to go for a 4320 cab. I don't think the cab is available on a 4120. The idea was, I would save almost enough in base tractor price to pay for the cab. As it turns out, I found a 2007 4720 cab with 760 hrs for less than the open station 4320 listed for. And it had a bunch of goodies on it that I wanted.
So is it ok to ask if a price from a unnamed dealer is a good price quote?
   / Anyone running a late model JD 4720? #14
Perfectly fine. People do it all the time. How much you looking at?
Well here we go. 2012 4720 ehydro, dual mid & single rear scv, power beyond kit, hard top canopy, 485 Backhoe, 18" and 24" buckets, 73" 400cx loader with tooth bar, deluxe hood guard, ROPS organizer, seat cover. front and rear work light kits.
$46983.00
60 months at zero percent.
   / Anyone running a late model JD 4720? #17
$46983.00
Did you build the tractor and add ons using the configurator to get the msrp price? I know the configurator was done for awhile. I recommend you do that if you haven't and then deduct 18% from the msrp price and add the sales tax back if applicable.
Also remember the 2007 4720 is the same hp as a new 4520, 60hp.
Yes, I did try the builder on JD website but the 485 backhoe option is not listed. So I figured I would ask the forum if the percentages looked correct. This dealer I recieved this quote from has never seen me in the past so I think he is being pretty fair as this is the first quote he hit me with.
   / Anyone running a late model JD 4720? #19
I have 40 ac most of what i do is mowing and brush mowing with a little loader work from time to time. i went from a 3720 to a 4720 because the 4720 is much more stable on hills and can push and pull a larger deck without too much effort. i'd think 15 ac is a bit small for a 4720 unless you're doing hay or something - both are great and the Yanmar engine in the 3720 is a bit more advanced then the JD -for example the Yanmar had self bleeding fuel pump and to me, it started with a bit less cranking fuss...never had any problems with either.
   / Anyone running a late model JD 4720? #20
If you go to DEERE-index, select commercial, utility tractors, attachments, you will find the 485 backhoe. For whatever reason, the backhoes are not shown on the related products page for the tractor.
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A51039)
2022 JCB 3TS-8T...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A50854)
2014 GOOSENECK...
CAT D6D (A50854)
CAT D6D (A50854)
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
