Tiller
/ Tiller #1
Jim Dodgins
West Virginia
Mahindra 3550, Kubota L235, Teryx LE, F350 dumper
I have a 3316 shutle and am in the prosses of buying a rear tiller and was wondering if my tractor could handle a 5' tiller , or would it be better to get a 4' tiller? Thanks
/ Tiller #2
Get the 5' as the tractor would handle more, the 4' wouldn't cover the tractor width.
/ Tiller
Thanks Galen, I think I will.
/ Tiller #4
Get a tiller wide enough to cover your tire tracks. 5ft probably for your 3316.
/ Tiller #5
I have always heard 5 HP per foot. I have a 3325 2wd (35 HP) and my tractor handles a 5 foot extremely well.
Don
/ Tiller #6
I have a 3016 and I have a Landpride RTA1566 tiller and it runs it with no problems. Definitely would suggest you get a tiller to cover tires or at least one you can offset.
/ Tiller
Thank all, it appears bigger is better.:D
/ Tiller #8
I use a Woods 5' tiller on my 3316HST. Works great. I did have to pull a middle buster through the ground first, though--the ground was hard enough that the tines of the tiller were bouncing off. The tractor never complained, though.
/ Tiller #9
Till when the soil is damp, it will dig right in.
To the OP, get a tiller wide enough to cover both tire tracks as others have said. You will be much happier............I'm talkin from experience. 13 years with an offset tiller that only covered 1 tire track.
Now I'm covered(pun intended):laughing::laughing:
New/Unused AGT SDA-140W Wheel Loader (A61166)
New/Unused AGT...
(2) 23.1-26/18-26 TRACTOR TIRES (A62131)
(2) 23.1-26/18-26...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
