Down pressure on 3 pt?
/ Down pressure on 3 pt? #21
/ Down pressure on 3 pt? #23
I made one on my L4350, works pretty slick, I have to keep the 3PH lever in the down position when I use it and use the down pressure cylinder to lift. It does allow a certain amount of grader type action but the weight of the tractor has a lot to do with it. I have been meaning to do some more refining and probably will when time allows.
/ Down pressure on 3 pt? #25
Hollow said:
The only tractor I've ever seen with 3pt down pressure was a Belarus.
Case made their "garden" tractors with hydraulic 3pt hitch
Worked well except when you would lift a drive wheel (2wheel drive)
Wish I had it now on b2920
/ Down pressure on 3 pt? #26
what difference would that make if he had draft control... that does not equal down pressure.. etc.. ???
I thought his purpose was to eliminate the humps in the middle of his driveway
caused by his vehicles going over a wet clay base before it dried out like concrete?
My driveway is .25 mile long with many layers of limestone of different sizes over 20 years added to the clay soil. It still gets humps as he described in the winter and spring and it too dries out like concrete in the summer. I adjust my rear blade at an angle and while it, and the tractor, are on level ground I drop the lift and draft levers all the way down then bring the draft back up just enough to hold the blade edge at ground level. A couple trips down and back gets rid of the hump and fills in the tire grooves. Then as it dries out more a couple passes with my landscsape rake brings the limestone up and evens it out. Looks like a new load after a rain washes off the clay from the stone.
It's not a perfect solution, I guess, and it takes some learning of the controls, but I have 20 years worth of that.
Most folks try to dig too deep with one pass and make a worse mess than before they started. The length of the top link is important too so the blade will dig in but not too aggressivly.
All this wouldn't matter in your Florida sand where the leveling is easy:)
/ Down pressure on 3 pt? #27
i box blade mine.. good set cut to get rid of the humps and bumps.. and thendrop the load into the pits..
whatever works I guess., is good!
/ Down pressure on 3 pt? #28
This.
Shallow pases, angled blade. Move the gravel over to the left, move the gravel over to the right. Move the gravel back to the middle. Go in the spring or whenever your ground just kinda starts to dry out. Angled blade gets rid of washboards. Straight blade or boxblade magnifies the washboards. Potholes you need to cut down the road to level of the bottom of the pothole all around, then get the gravel spread out again over the road level. Potholes like to reapear, just dumping loose gravel in the dips makes a pothole reappear.
Down pressure really isn't going to help a whole lot, angle & tilt of the blade means more.
And the last passes with a landscape rake are spot on, angled & a little on the faster side, brings the rock to the top. If I get the right day in spring here in MN, I just use the landscape rake, it cuts through the wet gravel good and levels everything up with about 5-6 rounds with the rake.
--->Paul
/ Down pressure on 3 pt? #29
Depending on what you want to do, how much of it is to be done, etc.
ONE alternative might be to use a FEL Skid Steer to 3pt adapter and do what needs to be done backwards.
I have one, I use it with a sub soiler for picking at roots, then spin around and use the hoe to get the rest of the root ball out.
It is also handy when I just need to throw a rake or something on and the back ends of all available tractors have hoes or some other inconveniently large implement on them.
/ Down pressure on 3 pt? #30
This.And the last passes with a landscape rake are spot on, angled & a little on the faster side, brings the rock to the top. If I get the right day in spring here in MN, I just use the landscape rake, it cuts through the wet gravel good and levels everything up with about 5-6 rounds with the rake.--->Paul
Same here in OH. A caution to any new rake owners on stone drives/lanes...
Count your tines and note any broken ones before and after the job. You would be amazed at how hard it is to find a broken tine under stone you have just raked.. The tines on my Woods rake are black from the manufacturer as are the replacements. A cheap can of red spray paint shot on the tines makes them easier to find sometimes. It even helps in a pasture if your spreading out horse apples or cow paddies. Ron
/ Down pressure on 3 pt? #31
Most 3 point hitch lift links (those are the parts that connect the rockshaft arms to the draft links) are designed to work in extension only, not compression. The seemingly simple act of replacing single acting external lift cylinders with double acting, or any other modification requiring the lift links to work in compression will only serve to bend them when the applied downforce exceed the lift links compressive strength. Plan on that happening sooner rather than later.
The limitations on rear axle traction when downforce is applied to a fully mounted implement are severely underrated in this discussuion.
Summary; 3 point systems don't have downforce because the practical advantages of having it are outweighed by the practical disadvantages. Most ground-engaging tools are designed to penetrate when properly adjusted. Those that don't are generally lighter, cheaper brands with little or no functional design engineering.
/ Down pressure on 3 pt? #32
An even EASIER way to find them is to buy your wife a NEW car.
ONE trip down a gravel driveway, they'll POP RIGHT OUT (-:
PS On the subject of a skid steer to 3 pt adapter to use implements on the front - & drive backwards.
I have done it a few times with a rake as well as a blade. I find that if I float it while stationary on level ground, then lock it to center the weight of the
FEL and implement are "about right", i.e. the inch or so of slack is a good starting point for leveling.
/ Down pressure on 3 pt? #33
That's for sure and likely break something...
My wife worries more about a horse stepping on one and having it flip up and cut a fetlock.
In any of these grading methods a good set of adjustable mirrors are a real friend if your old and don't want a stiff neck the next day!
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
John Deere 350 Sickle Mower (A66408)
John Deere 350...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
