Hose size for toplink cylinder?
   / Hose size for toplink cylinder? #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
Make any difference what size hose I use?
Cat II 3pt. 3" cylinder. As short as these hoses will be cost is not the deciding factor.
So 1/4", 3'8" or 1/2" ?
   / Hose size for toplink cylinder? #2
I have 3/8 and it is plenty.
   / Hose size for toplink cylinder? #3
I would use the 1/4 inch hose in a effort to slow down the flow of oil so the cylinder wont move too fast. I would also install flow restrictors in the lines if I could find some. I had no luck finding any locally the last time I wanted some.
   / Hose size for toplink cylinder? #4
1/4 in hose and a needle valve.
My rear SCVs, JD deluxe 301 series made by Husco, have built in flow control. Will that be enough with 1/4" hoses?
   / Hose size for toplink cylinder? #6
Probably. Connect up the 1/4 in hose and try it.
   / Hose size for toplink cylinder? #7
My JD 3rd SCV kit has the huge back hoe quick couplers, not sure on the hose but is definitely bigger than 1/4". There must be some type flow restriction in the system somewhere cause it doesn't move to quickly, very much in control. Could just be the cylinder.
When I hooked up a truck's snow plow to the rear remotes, even though they have 1/4" fittings the plow moved so fast I could do an NHL slap shot!
JB
   / Hose size for toplink cylinder? #8
   / Hose size for toplink cylinder? #9
Mine are 3/8" and I should of used 1/4". I'm putting a needle valve on it to slow it down.
   / Hose size for toplink cylinder? #10
I have flow restrictors, $10 ea + shipping. Install right behind your male quick connect end. 1/2" pipe thread.
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
